ZADAK, a leading provider of PC enthusiast components, announced today the official release of the SPARK AIO 240MM ARGB liquid CPU cooler with a 5-year warranty. With the two SPARK 120mm fans running at speeds of 500-1800 RPM while operating under 25dBA, users can equip their PC with efficient cooling with minimal noise. Also outfitted with customizable ARGB and a sleek pump design, this latest addition expands ZADAK liquid cooling line-up from the patented MOAB II water distribution plate to mainstream cooling featuring user-centric design.
Engineered for performance
The SPARK AIO 240 is equipped with two SPARK 120mm fans that deliver outstanding air pressure. The combination of the dual-fans running at speeds between 500-1800 RPM with a high static pressure of 2.5mm and the aluminum radiator of the highest fin density at 22 FPI, the SPARK AIO 240mm brings exceptional thermal exchange performance to keep even the most power hungry CPU’s running at full speed. In addition, the included SPARK 120mm fans operate at impressively quiet levels, emitting a stealthy 18-25dBA, even while the fans are running at higher RPMs. At these levels, the fans meet the noise standards of recording studios, making the SPARK AIO cooling system suitable for those in noise-sensitive fields such as streaming or video/music production.
More vibrant ARGB
The SPARK AIO liquid cooler also features world leading technology of 2nd generation ARGB lighting. Vibrant ARGB LEDs frame the radiator fans and ZADAK’s custom designed CPU pump head. The SPARK AIO is compatible with RGB software programs ASUS Aura Sync, MSI Mystic Light, ASRock Polychrome, and GIGABYTE RGB Fusion, which provides users more PC component and peripheral synchronization possibilities for the ultimate experience in RGB personalization.
The new SPARK AIO 240mm by ZADAK is available worldwide at MSRP of $159 USD. To learn more, please visit: https://www.zadak.biz/products/content/50
| Specifications | |
| Water block | |
| Dimensions | 72 x 72 x 47mm |
| Block Material (CPU Plate) | Copper |
| Radiator | |
| Dimensions | 272 x 121 x 27mm |
| Radiator Material | Aluminum |
| Tube | Sleeved rubber tubes |
| Fan | |
| Type | 2x ZADAK SPARK FAN 120mm |
| Dimensions | 120 x 120 x 25mm |
| Fan Speed | 500 ~ 1800 RPM +/- 10 % |
| Fan Static Pressure | 2.5 mm H2O |
| Fan Airflow | 46.34 CFM |
| Fan Noise | 18-25 dB(A) |
| Control Mode | PWM |
| Compatibility | |
| Intel | LGA 1150, 1151, 1152, 1155, 1156, 1366, 2011, 2011-3, 2066 |
| AMD | AM4 |
| Warranty | |
| Warranty | 5 years |
