Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone SX700-PT at 45c. This makes Test #1 equal to 185W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~400mV drop on the 12v rail and ~80mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~70mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone SX700-PT at 45c. This makes Test #2 equal to 327W by loading the 12v rail to 24a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~330mV drop on the 12v rail and ~70mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~70mV drop.
The Transient Load Tests results for the SilverStone SX700-PT are passing and generally good. In today’s testing, the SX700-PT saw the loaded 12v rail post a peak change of ~400mV, and the loaded 5v rail post a peak change of ~80mV. The unloaded 5v peak change during the 12v load was ~70mV. Those numbers are, in an absolute sense, decent for the 5v rail. Then, much as was the case with the SX700-G, the 12v rail results are good in a relative sense when we consider that this unit is an SFX product. However, this unit does trail what we saw from the SX700-G even though that unit is the same capacity. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
