DC Output Quality
Control Test Graphing
This image is the blank background control test on an unused connector from our SM-8800 during the testing of the SilverStone SX700-PT. This lets us determine what the background noise looks like during testing.
120v Input
100v Input
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone SX700-PT at 45c. This makes Test #1 equal to 185W by loading the 12v rail to 13a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a. The SilverStone SX700-PT is starting off in excellent shape. All of the rails we monitor are peaking at less than ~10mV of ripple/noise.
120v Input
100v Input
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone SX700-PT at 45c. This makes Test #2 equal to 327W by loading the 12v rail to 24a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a. Test #2 sees only minor changes as the 12v rail is coming in at ~10mV of ripple/noise, the 5v rail is coming in at less than ~10mV of ripple/noise, and the 3.3v rail is peaking at less ~10mV of ripple/noise.
120v Input
100v Input
Test #3 is equal to approximately 75% of the rated capacity of SilverStone SX700-PT at 45c. This makes Test #3 equal to 488W by loading the 12v rail to 36a, the 5v rail to 5a, the 3.3v rail to 4a, the +5vsb to 2a, and the -12v to 0.3a. Test #3 sees the 12v rail peaking at ~25mV of ripple/noise while the minor rails are coming in at ~10mV of ripple/noise.
120v Input
100v Input
Test #4 is equal to approximately 100% of the rated capacity of the SilverStone SX700-PT at 45c. This makes Test #4 equal to 697W by loading the 12v rail to 56a, the 5v rail to 1a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a. In the final regular test, we see the 12v rail peaking at ~35mV of ripple/noise while the minor rails are peaking at ~15mV of ripple/noise on the 3.3v rail and ~10mV on the 5v rail.
Torture Test
The Torture Test is equal to approximately 80% of the rated capacity of the SilverStone SX700-PT at 45C. This makes the Torture Test equal 572W by loading the 12v rail to 42a, the 5v rail to 7a, the 3.3v rail to 5a, the +5vsb to 2a, and the -12v to 0.3a. At the end of the Torture Test, we see the 12v rail peaking at ~30mV of ripple/noise while the 3.3v rail is peaking at ~25mV of ripple/noise and the 5v rail is peaking at ~15mV of ripple/noise.
DC Output Quality Summary
The overall DC Output Quality of the SilverStone SX700-PT is good. The SX700-G ended up posting a peak trace amplitude on the 12v rail of ~35mV followed by ~25mV on the 3.3v rail and ~15mV on the 5v rail. The worst relative value among these hit ~50% of the ATX12v specification limit and this unit was a bit worse in this aspect of testing than the SilverStone SX700-G. So, it seems that while this unit may be more current and more efficient it is not better when it comes to DC Output Quality. Let’s move on now and see how all of this wraps up!
