The EVGA BA Power Supplies are here to add that final luster to your PC without leaving a hole in your wallet. Certified 80PLUS Bronze, BA power supplies utilize a DC-DC converter to make sure value does not come at the expense of efficiency. Powered by a single +12V rail, EVGA BA power supplies are burnished with a full suite of protections and all the cables you need to build a modern gaming PC.
- 80 PLUS Bronze Efficiency
- 80 Plus Certification ensures your power supply isn’t wasting power and turning it into excess heat. Under typical load this power supply is 85% efficient or higher.
- Hard Lined Design
- Hard lined design allows your cables to be attached to the power supply for ease of installation and removal. You can be ready to go right out of the box.
- DC to DC Converter
- Voltage step-down for rock-solid power stability and minimal signal noise. (For 3.3V and 5V)
- Long Sleeve Bearing Fan
- A 120mm Long Life Sleeve Bearing fan results in quieter operation and a longer lifespan.
Made to Protect and Serve
The EVGA BA Series also includes a full suite of protections (OCP, OVP, UVP, OPP, SCP, OTP) for safety and security.
World leading warranty and support for 3 Years
3 Year Limited Warranty available for BA models with a -KX suffix.
5 Year Limited Warranty available in select regions for BA models with a -VX suffix.
