LIAN LI Industrial Co. Ltd., a leading manufacturer of aluminum chassis and PC accessories, is proud to announce its first closed-loop All-in-One Liquid Coolers, the GALAHAD 240 and GALAHAD 360. Available in black or white, the new GALAHAD series features a unique triple chamber pump design and PWM high static pressure fans to ensure optimal thermal and noise management. Keeping ease of installation, flexibility, and style in mind, the GALAHAD is compatible with the latest Intel and AMD sockets and is equipped with 400mm braided tubing. Fans and CPU block feature addressable RGB which can be synchronized with your motherboard software for unified lighting effects.
Focused on performance
The GALAHAD 240 and 360 deliver on performance by combining a unique triple chamber pump design with low-noise fans engineered to deliver an optimal airflow over the high-density aluminum radiator. The CPU block of the GALAHAD consists of a cold plate chamber, a connecting chamber and a pump chamber. The special design eliminates water flow dead zones while providing a direct path and maximum pressure over the fins of the cold plate which results in fast heat dissipation. With all compatibility accessories for both AMD and Intel sockets included, the GALAHAD is easy to install.
With a pump operating at less than 20 dBA at full speed and PWM fans that can operate between 800 and 1900 RPM, the GALAHAD will not affect your gaming experience with disturbing background noise. Capable of offering a maximum airflow of 69.17 CFM and air pressure of 2.6 mmH20, the included high static pressure fans of the GALAHAD are quiet yet powerful, thanks to their industrial-grade motor, fluid dynamic bearing and extra magnetic support which all work together to eliminate friction and vibrations.
Premium quality
While the GALAHAD performance is outstanding, it also features premium quality and design. The aluminum housing of the radiator and CPU block gives the GALAHAD a classic and robust look. Paired with 400mm high-end braided tubing, the GALAHAD is a perfect fit for midi tower and full tower chassis.
The fans and CPU block are equipped with addressable RGB LEDs that can be synchronized with the motherboard lighting software. Capable of supporting a wide array of lighting effects, a total of 17 modes including 7 solid colors are available. The included RGB controller makes switching between effects a breeze. In addition, the CPU block can be rotated to ensure a properly aligned logo no matter what the orientation of the block is. It also features a magnetic aluminum cap which can be removed and reveal the LIAN LI logo and a brighter lighting effect.
Backed by a 5-year warranty, the GALAHAD AIO is available for pre-order starting July 31st, 2020, at MSRP $119.99 USD for the 240, and $149.99 USD for the 360.
LIAN LI GALAHAD 240/360 Specifications
Radiator Materials | Aluminum and plastic |
Radiator Dimensions | (L) 397.5mm x (W) 123.5mm (H) 27mm / (L) 273mm x (W) 123.5mm (H) 27mm |
Fan Dimensions | (L) 120mm x (W) 120mm x (H) 26mm |
Fan Speed | 800 – 1900 RPM (PWM) |
Fan Airflow | 69.17 CFM |
Fan Air Pressure | 2.6 mm H2O |
Fan MTTF | 40,000 Hours |
Fan Power Connector | 4-Pin |
Fan Rated Voltage | 12V DC |
Pump Dimensions | (L) 87.1mm x (W) 74mm x (H) 62mm |
Pump MTTF | 70,000 Hours |
Pump Noise Level | < 20 dBA |
Pump Power Connector | 2510-3-Pin |
Pump Rated Voltage | 12V DC |
Compatible CPU sockets | Intel: LGA 115X, LGA 1366, LGA 775, LGA 1200, LGA 2011, LGA 2066 AMD: AM4 |
Warranty | 5 years (Fans limited to 2 years) |
