Test Setup
We will use our standard AIO test rig which you can read more about in its introduction article. We will set up each cooler in the same manner with the radiator attached to the case and the fans blowing into the radiator. The water blocks will be mounted per the manufacturer’s instructions except that we will use Arctic Cooling MX-2 thermal paste (2019 Edition). We will also compare it to the other coolers we have tested thus far.
Installation
Installation was straightforward on our test bench. The radiator installed without a hitch and the water block went on shortly thereafter.
With everything comfortably situated, let’s start seeing what kind of numbers the SilverStone PF240-ARGB can put up today!
