Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the SilverStone DA1650 at 45c. This makes Test #1 equal to 412W by loading the 12v rail to 32a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~250mV drop on the 12v rail and ~45mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~40mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the SilverStone DA1650 at 45c. This makes Test #2 equal to 829W by loading the 12v rail to 65a, the 5v rail to 5a, the 3.3v rail to 3a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~240mV drop on the 12v rail and ~40mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~30mV drop.
The Transient Load Tests results for the SilverStone DA1650 are passing and very good. In today’s testing, the DA1650 saw the loaded 12v rail post a peak change of ~250mV, and the loaded 5v rail post a peak change of ~45mV. The unloaded 5v peak change during the 12v load was ~40mV. Those numbers are, in an absolute sense, very good across the board. In a relative sense, we do not have any other units to compare this unit to. However, it is a 1650W unit, so the loads used here are a small fraction of this unit’s capacity. So, good results are expected, and these are good, but they could be a bit better all things considered. By all things, I mean there are 1650 things here! Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
