GIGABYTE has listed a new version of its custom AORUS GeForce RTX 3080 MASTER 10G graphics card. As noted by momomo_us (via Tom’s Hardware), the main difference in revision 2.0 is the presence of not two but three 8-pin PCIe power connectors and an increased recommended PSU rating of 850 vs. 750 watts. The popular theory is that this revision leverages the same PCB as the AORUS GeForce RTX 3080 XTREME 10G and was introduced mostly as a cost-cutting measure.
The AORUS GeForce RTX 3080 MASTER 10G features a core clock of 1,845 MHz, which is 135 MHz faster than NVIDIA’s GeForce RTX 3080 Founders Edition (1,710 MHz). Some of the card’s unique features include a Max-Covered cooling system comprising two 115 mm and one 100 mm blade stack fans with wind claw design and alternate spinning, as well as an LCD Edge View display that can be customized to display various information such as GPU temperature and clock speeds.
Key Features
- NVIDIA Ampere Streaming Multiprocessors
- 2nd Generation RT Cores
- 3rd Generation Tensor Cores
- Powered by GeForce RTX™ 3080
- Integrated with 10GB GDDR6X 320-bit memory interface
- MAX-COVERED cooling
- LCD Edge View
- RGB Fusion 2.0
- 6 video outputs
- Protection metal back plate
- 4 years warranty (Online registration required)
AORUS GeForce RTX 3080 Specifications
| AORUS GeForce RTX 3080 XTREME 10G | AORUS GeForce RTX 3080 MASTER 10G (rev. 1.0) | AORUS GeForce RTX 3080 MASTER 10G (rev. 2.0) | |
| Graphics Processing | GeForce RTX 3080 | GeForce RTX 3080 | GeForce RTX 3080 |
| Core Clock | 1905 MHz (Reference Card: 1710 MHz) | 1845 MHz (Reference Card: 1710 MHz) | 1845 MHz (Reference Card: 1710 MHz) |
| CUDA® Cores | 8704 | 8704 | 8704 |
| Memory Clock | 19000 MHz | 19000 MHz | 19000 MHz |
| Memory Size | 10 GB | 10 GB | 10 GB |
| Memory Type | GDDR6X | GDDR6X | GDDR6X |
| Memory Bus | 320 bit | 320 bit | 320 bit |
| Memory Bandwidth (GB/sec) | 760 GB/s | 760 GB/s | 760 GB/s |
| Card Bus | PCI-E 4.0 x 16 | PCI-E 4.0 x 16 | |
| Digital max resolution | 7680×4320 | 7680×4320 | 7680×4320 |
| Multi-view | 4 | 4 | 4 |
| Card size | L=319 W=140 H=70 mm | L=319 W=140 H=70 mm | L=319 W=140 H=70 mm |
| PCB Form | ATX | ATX | ATX |
| DirectX | 12 Ultimate | 12 Ultimate | 12 Ultimate |
| OpenGL | 4.6 | 4.6 | 4.6 |
| Recommended PSU | 850W | 750W | 850W |
| Power Connectors | 8 pin*3 | 8 pin*2 | 8 pin*3 |
| Output | DisplayPort 1.4a *3 HDMI 2.1*2, HDMI 2.0*1 (The middle HDMI output supports up to HDMI 2.0) | DisplayPort 1.4a *3 HDMI 2.1*2, HDMI 2.0*1 (The middle HDMI output supports up to HDMI 2.0) | DisplayPort 1.4a *3 HDMI 2.1*2, HDMI 2.0*1 (The middle HDMI output supports up to HDMI 2.0) |
| SLI Support | N/A | N/A | N/A |
| Accessories | 1. Quick guide 2. 4-year warranty registration 3. Metal sticker 4. Xtreme robot limited edition | 1. Quick guide 2. 4-year warranty registration 3. Metal sticker | 1. Quick guide 2. 4-year warranty registration 3. Metal sticker |
Gigabyte AORUS GeForce RTX 3080 MASTER 10G (rev. 2.0)https://t.co/Y57Q5S7Tj7
— 188号 (@momomo_us) January 2, 2021
>Power Connectors : 8 pin*3 pic.twitter.com/gW58J9AfXt
