VideoCardz has shared a small slide deck that provides a bit of insight on MSI’s upcoming GeForce RTX 3080 Ti and GeForce RTX 3070 Ti SUPRIM graphics cards. While there isn’t much in the way of specifications, the presentation does confirm that these custom GeForce RTX 3080 Ti and GeForce RTX 3070 Ti models will feature 12 GB and 8 GB of memory, respectively. The slides also point out the SUPRIM family’s unique features, which include a TRI FROZR 2S cooling system comprising TORX FAN 4.0, Airflow Control fins, a core pipe, and metal backplate. NVIDIA will reportedly announce the GeForce RTX 3080 Ti and GeForce RTX 3070 Ti on May 29.
MSI marketing materials clearly confirm that RTX 3080 Ti and RTX 3080 are to share the PCB design. The same would apply to RTX 3070 Ti and RTX 3070 series. This would also be a confirmation on GA104 GPU on RTX 3070 Ti, which can be concluded from the PCB photo (GA102 and GA104 GPUs have a different layout of capacitors). The RTX 3070 Ti is expected to feature a full GA104 GPU with 6144 CUDA cores.
Source: VideoCardz
