GIGABYTE has published the official product page for one of its upcoming tactical gaming monitors, the AORUS FI32U. This is a 31.5-inch display that leverages a 4K UHD (3840 x 2160) SuperSpeed IPS panel with a refresh rate of up to 144 Hz, response time of 1 ms GTG/1 ms MPRT, and support for DisplayHDR 400. Connectivity options include x2 HDMI 2.1, x1 DisplayPort 1.4 (DSC), x3 USB 3.0, and 1x USB-C.
AORUS FI32U Gaming Monitor Specifications
| Display Viewing Area (HxV) | 697.3056 X 392.2344 (mm) |
| Panel Backlight/ Type | Edge type |
| Display Surface(non-glare/ glare) | Non-glare |
| Color Saturation | 95% DCI-P3/ 123% sRGB |
| True Resolution | 3840 X 2160 (UHD) |
| Pixel Pitch | 0.181 (H) X 0.181 (V) (mm) |
| Brightness | 350 cd/m2 (TYP) |
| Contrast Ratio | 1000 1 (TYP) |
| Viewing Angle | 178 (H)/178 (V) |
| Display Colors | 10 bits (8 bits + FRC) |
| Response Time | 1ms GTG / 1ms MPRT |
| Refresh Rate | 144Hz 120Hz for Console Game* |
| HDR | VESA Display HDR400 |
| Flicker-free | Yes |
| Signal Input | HDMI 2.1 x2 Display port 1.4 (DSC) x1 |
| HBR3 | Yes |
| Earphone Jack | Yes |
| Microphone Jack | Yes |
| Speaker | N/A |
| Unique Features | OSD Sidekick Active Noise Cancelling (ANC) 2.0 Aim Stabilizer Sync Black Equalizer 1.0 Dashboard Timer Counter Crosshair PiP/PbP Auto-Update KVM RGB Fusion 2.0 6 axis Color Control Smart OD |
| USB port(s) | USB 3.0 x3 USB C x1 |
| Power Type | Build-in |
| Power Consumption | 120W (Max) |
| Power Saving Mode | 0.5W |
| Power Off Mode | 0.3W |
| Voltage | AC 100-240V 50/60Hz |
| Tilt(angle) | -5 °++20° |
| Swivel(angle) | -20°-+20° |
| Pivot(angle/direction) | -0° -+90 |
| Height Adjustment (mm) | 130 |
| VESA Wall Mounting(mm) | 100*100 |
| Kensington lock | Yes |
| Phys. Dimension with Stand(WxHxD) | 717.6*424.3*71.3 mm |
| Phys. Dimension w/o stand (WxHxD) | 715.8*423.8*68.2 mm |
| Box Dimension (WxHxD) | 1000*585*198 mm |
| Net Weight with stand (Esti.) | 10.9 kg (TBD) |
| Net Weight without stand (Esti.) | 7.7 kg (TBD) |
| Gross Weight (Esti.) | 15.4 kg (TBD) |
| Accessories | Power cable/HDMI cable/DP cable/USB cable/Type C cable/QSG/Warranty card |
| Note | *HDMI2.1 supports PS5 and Xbox Series X at 4K UHD@ 20Hz (4:2:0) |
Adaptive-sync is supported for VRR from both compatible NVIDIA and AMD systems. […] Other specs now confirmed via the Gigabyte product page include a 1000: contrast ratio, 350 cd/m2 brightness and 178/178 viewing angles. […] The screen also offers “audiophile sound” as Gigabyte put it, with Audi ESS Sabre Hi-fi.
Sources: GIGABYTE, TFT Central
