Transient Testing
Transient Test 1
Loaded/Unloaded
12v/5v
Test #1 is equal to approximately 25% of the rated capacity of the FSP DAGGER PRO 550W at 45c. This makes Test #1 equal to 148W by loading the 12v rail to 10a, the 5v rail to 2a, the 3.3v rail to 1a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #1 show a ~400mV drop on the 12v rail and ~40mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~30mV drop.
Transient Test 2
Loaded/Unloaded
12v/5v
Test #2 is equal to approximately 50% of the rated capacity of the FSP DAGGER PRO 550W at 45c. This makes Test #2 equal to 277W by loading the 12v rail to 20a, the 5v rail to 3a, the 3.3v rail to 2a, the +5vsb to 2a, and the -12v to 0.3a before the addition of the transient load. The results of Test #2 show a ~395mV drop on the 12v rail and ~45mV drop on the 5v rail when each is directly loaded. At the same time that the load was being triggered on the 12v rail, the 5v rail measured a ~35mV drop.
The Transient Load Test results for the FSP DAGGER PRO 550W are passing but mixed. In today’s testing, the DAGGER PRO 550W saw the loaded 12v rail post a peak change of ~400mV, and the loaded 5v rail post a peak change of ~45mV. The unloaded 5v peak change during the 12v load was ~35mV. Those numbers on the minor rail are, in an absolute sense, excellent. On the 12v rail, those numbers are not so excellent in an absolute sense or a relative sense. Overall, this unit was mixed with the Bitfenix Formula Gold 550W entirely because of the 12v rails’ rather weak performance today. So, rather than being the best 550W unit we have seen in this aspect of testing, the DAGGER 550W is very much average overall to date due to the rather weak 12v performance. Let’s move on now to see how this unit does in the DC Output Quality aspect of our testing!
