MSI has introduced its first silent gaming PC case, the MPG QUIETUDE 100S. A potential contender to cases offered by noise-conscious companies like Fractal and be quiet!, MSI’s MPG QUIETUDE 100S features a variety of noise dampening features and premium materials such as sound dampening foam and a fan speed control button that allows users to quickly switch between three stages of RPM (100, 70 and 0 percent) when desired. MSI’s MPG QUIETUDE 100S case also features the manufacturer’s new MEG SILENT GALE P12 fan, which leverages liquid-crystal polymer fan blades, a hydro-dynamic bearing, an anti-vibration fan gasket, and more to ensure quieter operation.
| Product Name | MPG QUIETUDE 100S |
| Support MB Form Factor | E-ATX/ ATX/ M-ATX / ITXX |
| Dimension | 475×231 x490mm/ 18.7×9.1×19.3 inches |
| I/O Ports | 2x USB 3.2 Gen 1/ 1 x USB 3.2 Gen 2 Type-C/ 1xAudio / 1 x Mic |
| Driver Bays | 2.5″SSD x2/3.5″HDDx2 |
| VGA Card Support | 380mm/ 15inches |
| CPU Cooler Support | 175mm/6.9inches |
| Power Supply | Standard ATX, maxup to 250 mm(without 3.5″HDD case installed) |
| Cooling Layout | Front: 120mm x3 or 140mm X3 Top: 120mm x3 or 140mm x 2 Rear: 120mm x 1 |
| Radiator Layout | Front: 120/ 140 / 240 /280/360mm Top: 120/140 /240 / 280/360mm Rear: 120 mm |
The MPG QUIETUDE 100S is also an extremely capable gaming PC case. It features a VGA support bracket that can sustain graphics cards of different weights and sizes. On its side is a hinged tempered glass swinging window that offers the best durability and system accessibility. If cooling performance something you care about, worry not. The MPG QUIETUDE 100S is optimized to provide effective airflow and can mount up to 7 fans in total.
