TEAMGROUP has announced a pair of new products. The first is an upgraded version of its Siren AIO cooler that now includes mounting hardware for Intel’s LGA 1700 socket. The SIREN GD240E AIO ARGB cooler ($109.99) features a 4,000 RPM pump that is installed directly on the radiator. ARGB features are controllable via most major motherboard applications, and the block features a mirror finish with the TEAMGROUP logo.
SIREN GD240E AIO ARGB CPU Liquid Cooler
The newly upgraded SIREN GD240E AIO ARGB CPU Liquid Cooler not only supports various older Intel and AMD sockets but also provides a mounting kit for the latest LGA 1700 socket. The specially selected base plate, support screws, and mounting brackets enable the water block to fit snugly with the processor. The full and even contact between the surfaces aids heat transfer swiftly to the high-density jet fin heat sink, greatly increasing the heat dissipation area and quickly removing heat from the CPU. To optimize efficiency and the path of heat transfer, the SIREN GD240E is equipped with an ultra-fast 4000RPM water pump that’s installed on the radiator to reduce wear and noise on the CPU caused by water pump vibrations. These features allow the system to deliver 1.5 times higher cooling performance than typical liquid-cooled products while also providing the best protection for the next-gen Intel processors. The SIREN GD240E is an all-in-one liquid cooler system with top-notch heat dissipation and visual flair thanks to the water block’s elegant mirror finish and high-speed ARGB fans that support all major motherboard lighting software.
M200 Portable SSDs
Next are new TEAMGROUP M200 portable SSDs in 2 TB, 4 TB, and 8 TB storage capacities with up to 2,000 MB/s transmission speeds. Connectivity options include 1x USB 3.2 Gen 1, 1x Type A, and Type C OTG ports. Pricing ranges from $309.99 to $1,899.99, and various models will launch beginning later this month.
The M200 Portable SSD has a USB 3.2 Gen 2×2 interface, which delivers a blazing fast speed of 2,000MB/s, four times that of USB 3.2 Gen 1 external SSDs. It also features USB Type A and Type C OTG capabilities and supports a wide range of platforms, including tablets, smartphones, and PlayStation and Xbox consoles. With a total weight of only 83 grams and a maximum capacity of 8TB, the M200 Portable SSD is lightweight and portable, giving you easy access to fast drive speeds and massive storage at any time.
Pricing
| PRODUCT | SPEC | MSRP (USD) | TIME AVAILABLE |
| SIREN GD240E All-In-One ARGB CPU Liquid Cooler | - | 109.99 | Early December |
| M200 Portable SSD | 2TB | 309.99 | Late December |
| M200 Portable SSD | 4TB | 759.99 | Late December |
| M200 Portable SSD | 8TB | 1899.99 | Q1 of 2022 |
Source: TEAMGROUP
