AOC Announces Porsche Design 32-Inch 4K 144 Hz Monitor with HDR 1400 for $1,799
Image: AOC
AOC has announced the Porsche Design AOC AGON PRO PD32M, a premium 32-inch gaming monitor with a sleek design that may also be of interest to content creators.
The AOC AGON PRO PD32M features a 4K 144 Hz Mini-LED panel with peak brightness of 1600 nits, 1-ms response time, HDR 1400, 97% support of the DCI-P3 color space, and support for Adaptive Sync. It has two speakers, a 3.5 mm headphone jack, a headset holder, and is DTS-certified.
Connectivity includes 2x HDMI 2.1, 1x DisplayPort, 1x USB-C, and 4x USB Type 3.2 Gen 1. The aluminum stand allows for rotating the panel from portrait to landscape. The AOC AGON PRO PD32M is available for pre-order for $1,799.00 and will launch on June 15.
Description
Visible dynamism combined with the performance of AGON by AOC gaming technologies: the Porsche Design AOC AGON PRO PD32M sets new standards in the field of gaming monitors. The 32-inch mini-LED display represents the pinnacle of monitor performance. It rests on a trapezoidal aluminum stand designed in the style of Porsche steering wheels. The bold, streamlined design of the monitor also takes its inspiration from the world of Porsche sports cars. If the outside promises performance, the inside delivers: the panel, Display HDR 1400-certified with 4K resolution and a wide color space of 97% DCI-P3, ensures outstanding visual reproduction for games, streaming and graphics. The high refresh rate (144 Hz), a 1 ms response time, AdaptiveSync, and the impressive, detailed graphics reproduction (peak brightness of 1.600 nits) make for an even more fluid game experience. Full range of ports as well as an adjustable stand add the convenience that most demanding gamers need.
Details
• Frameless 32″ mini LED display for gaming, streaming, and graphics.
• 4K display resolution, 144 Hz refresh rate, Display HDR 1400-certified display, and wide color space of 97% DCI-P3.
• Two 8-watt speakers, DTS Sound-certified.
• Ports: 2x HDMI (supports HDMI 2.1), 1x DisplayPort, 1x USB type C, 4x USB 3.2, headphones.
• Light FX, LED Logo projection
• Wireless Quick Switch
• Headset-holder
DIMENSIONS
613mm x 290mm x 715mm
WEIGHT
11520g
Source: AOC (via Tom’s Hardware)
