EVGA has launched its E1 PC chassis that is available in 3 different kits to choose from ranging in price from $1599.99 – $4999.99. Announced in January, the E1 open frame PC chassis is made from 100% 3K plain weave carbon fiber and features an independent steel cable suspension for the motherboard and other components. The base model comes with the FRAME set and a GPU vertical mounting kit. The other two kits add in a GeForce RTX 3090 Ti K|NGP|N HYBRID GAMING and 1600 W T2 power supply. The ironically named BARE BONES edition throws in a premium carrying case, Z690 Dark K|NGP|N motherboard, and a Powerlink 52U adapter. All models include an analog gauge set with I/O ports and RGB controls.
Introducing the EVGA E1 – the new definition of style and substance in the form of a PC chassis. The E1 chassis frame is constructed with 100% 3K plain weave carbon fiber to sport the lightest frame design compared to other chassis of the same volume at only 2.76lbs. The E1 further sets itself apart from the competition with a patent-pending independent suspension system comprised of steel cables giving the E1 enough strength to hold even the heaviest of PC builds.
Monitor your system vitals via the included Analog Gauge set or digitally through the all new E1 Software to always know where you stand. EVGA’s full suite of software will keep your system operating at peak performance and give you full control over your RGB LED devices.
E1 Specifications, Dimensions, and Accessories
- 100% 3K Plain Weave Carbon Fiber Frame
- Patent-Pending Independent Suspension System
- Analog Gauge Set
- Supports mini-ITX, mATX, ATX, and E-ATX form factor
- Supports 1x 360mm radiators (*not included)
- USB 3.2 Gen 2 Type-C x1, USB 3.2 Gen 1 Type-A x2 on front I/O
- Designed for EVGA E1 control
- Length: 23.2in – 590 mm
- Width: 12.6in – 320 mm
- Height: 24.0in – 610 mm
- Weight: 9.886lb/4.484Kg
- Analog Gauges Set
- E1 Feet x4
- Quick Guide
- 4 Steel Cable ( For Backup)
- Hex Key
| EVGA E1 BARE BONES – $4999.99 | EVGA E1 KIT 1 – $3699.99 | EVGA E1 KIT 2 – $1599.99 |
| E1 FRAME Set | E1 FRAME Set | E1 FRAME Set |
| RTX 3090 Ti K|NGP|N | RTX 3090 Ti K|NGP|N | VGA Vertical Kit |
| PowerLinkâ„¢ 52u | VGA Vertical Kit | |
| VGA Vertical Kit | PSU 1600 T2 | |
| MB Z690 DARK K|NGP|N | ||
| PSU 1600 T2 | ||
| Premium Shipping Case |
The EVGA E1 BARE BONES premium carrying case is designed by Pelican and valued at $800.00.
Source: EVGA
