GIGABYTE Reveals Monstrous Size of AORUS GeForce RTX 4090 MASTER 24G Graphics Card
Image: GIGABYTE
GIGABYTE has revealed the physical dimensions for the AORUS GeForce RTX 4090 MASTER 24G, and they can confirm that the custom graphics card will be quite the monstrosity. The AORUS GeForce RTX 4090 MASTER 24 measures L=358.5 W=162.8 H=75.1 mm, according to an updated specifications table, indicating that it will dwarf even the GeForce RTX 3090 Ti in size.
Image: GIGABYTE/VideoCardz
From a VideoCardz report:
AORUS Master is equipped with three 11 cm fans. To give you some perspective, Mini-ITX GPUs can be as small as 17 cm. With a length of 35.8 cm and width of 16.2 cm, this card could easily fit four stacked ITX cards inside, and yes, we did the math.
The volume of RTX 4090 Aorus Master is 4,383 mm³, which is five times the volume of Gigabyte’s own ITX card. Alternatively, it could fit almost ten Radeon RX 6400 low profile cards. There is probably no scientific point in these calculations, but the size gap between RTX 40 and 30 series is already staggering.
GIGABYTE has confirmed that the AORUS GeForce RTX 4090 MASTER 24G will be available in October, alongside other models that include the AORUS GeForce RTX 4090 XTREME WATERFORCE and GeForce RTX 4090 GAMING OC. These will be followed by the company’s GeForce RTX 4080 options in November.
