TEAMGROUP to Launch T-FORCE DELTA RGB DDR5 7,600 MHz Memory
Image: TEAMGROUP
TEAMGROUP has announced that it will launching a new version of its T-FORCE DELTA RGB DDR5 desktop memory that features a frequency of 7,600 MHz. Joining the existing options (which range from 7,200 to 4,800 MHz), the new memory has been tested with 13th Gen Intel Core “Raptor Lake” processors on Z790 motherboards from major motherboard manufacturers and has been proven to be compatible. It will presumably be available with either black or white heat spreaders like the rest of the series.
  • RGB Colors & 120° Ultra-Wide Lighting
  • Supports Intel XMP3.0 for One-Click Overclocking
  • Power Management ICs (PMIC) Equipped for Stable, Efficient Power Usage
  • Strengthened PMIC Cooling Design
  • On-die ECC for Stable System
  • High-Quality ICs Selected for Stability & Reliability
  • Equipped with Smart RGB IC Controller that Supports Various Lighting Effect Software
Image: TEAMGROUP
From a TEAMGROUP press release:
TEAMGROUP’s gaming label, T-FORCE, has announced today that the T-FORCE DELTA RGB DDR5 will be launching a 7,600MHz high clock rate OC memory, breaking the world record and delivering a high-performance gaming DDR5 OC memory to gamers pursuing the ultimate performance. The latest T-FORCE DELTA RGB DDR5 has been tested with the Intel 13th-Gen Raptor Lake on Z790 motherboards from major motherboard manufacturers and has proven to be compatible. With outstanding R&D capabilities, T-FORCE continues to bring DDR5 performances to new heights for gamers.
T-FORCE LAB continues to push the limits of DDR5’s overclock speeds through research and development. The team also works closely with many motherboard manufacturers for testing to ensure that the high-performance T-FORCE gaming OC memory is fully compatible with most major motherboards on the market. The frequency specs from 4,800MHz to 7,200MHz have already been certified for Intel XMP3.0, gamers can launch the intel XMP3.0 OC function directly from their BIOS system. The compatible DDR5 OC memory module and process optimize the gaming experiences and delivers an incredibly powerful experience to consumers around the world.
TEAMGROUP’s gaming label, T-FORCE, will continue to meet gamers’ demands for high-frequency OC. In developing the new DDR5 platform, T-FORCE will also continue to pave the way for the industry and deliver cutting-edge DDR5 gaming OC memory to gamers, bringing them beyond the limits.
