ASUS Republic of Gamers (ROG) has announced its new ROG Ryuo III AIO cooler series in the form of the ROG Ryuo III 360 ARGB and the ROG Ryuo III 240 ARGB. Available in black or white editions, these are the first ROG AIO coolers from ASUS to feature an 8th generation Asetek pump. Another highlight is the AniMe Matrix, a display that lets users show off system stats, animations, and other content.
ROG RYUO III 360 ARGB
- The latest 8th gen Asetek pump is armed with a 3-phase motor that delivers ultimate cooling performance with higher flow and lower impedance
- The ASUS-exclusive Anime Matrix is a mini LED array that can display ROG-exclusive anime content, core system stats, and customized animations
- Premium ROG ARGB fans offer high airflow and optimized noise levels
- Aluminum components and vacuum coating provide high durability and flagship aesthetics
- The ROG Ryuo series is styled to complement the ROG motherboards at the heart of a high-end build
ROG RYUO III 240 ARGB
From an ASUS press release:
ASUS Republic of Gamers (ROG) today announced a new series of ROG Ryuo III AIO coolers, with four models to choose from: the ROG Ryuo III 360 ARGB and the ROG Ryuo III 240 ARGB, both available in black or white editions.
As the first ROG AIO coolers equipped with an 8th generation Asetek pump, the ROG Ryuo III 360 ARGB and ROG Ryuo III 240 ARGB offer exceptional cooling potential, making them ideal partners for the latest high-end chips from Intel and AMD. This pump sports a 3-phase motor capable of higher flow rates than previous generations, all while operating more quietly. The square cold plate is larger than the previous generation, and its size makes it ideal for this year’s hot-off-the-press CPUs.
Users will find the dazzling AniMe Matrix display on select ROG laptops, peripherals and motherboards — and now, they can bring it to the beating heart of their PCs with the ROG Ryuo III 360 ARGB and ROG Ryuo III 240 ARGB. This array of mini-LEDs right on top of the pump housing lets users show off ROG-exclusive content, core system stats and custom animations with unforgettable style.
The diamond-cut bezel along the top edge of the housing focuses attention on the display. To maintain the aesthetic of the device under all circumstances, ASUS installs a vacuum-coated lens above the display. This special glass will not let users see through the mini-LED array to the hardware underneath when their PC is powered off or when they have chosen not to use any lighting effects.
To find out more about the new ROG Ryuo AIO coolers, read this article on the ASUS Edge Up website.
