Phanteks has announced the release of the Glacier G40 ASUS GPU block, a new high-performance water-cooling solution that was designed specifically for ASUS TUF and ROG Strix GeFore RTX 4090/4080 Series graphics cards. Offering what the company has described as ultimate cooling performance, the GPU block features a transparent acrylic jet plate to ensure optimal heat transfer and a backplate that provides a smooth, integrated look and additional cooling. Phanteks’ Glacier G40 ASUS GPU block is available now in three colors, starting at $249.99.
Pricing:
- SATIN BLACK €249.90 / £229.90 / $249.99
- CHROME €269.90 / £244.90 / $269.99
- MATTE WHITE €269.90 / £244.90 / $269.99
Compatibility:
- ASUS ROG Strix GeForce RTX 4090 24GB
- ASUS ROG Strix GeForce RTX 4090 OC Edition 24GB
- ASUS ROG Strix GeForce RTX 4080 16GB GDDR6X OC Edition
- ASUS TUF-RTX4090-O24G-GAMING
- ASUS TUF-RTX4090-24G-GAMING
- ASUS TUF-RTX4080-16G-GAMING
- ASUS TUF-RTX4080-O16G-GAMING
From a Phanteks press release:
Phanteks announces the release of the new Glacier G40 ASUS GPU block, designed specifically for the ASUS STRIX/TUF RTX 4090/4080 Series cards. The Glacier G40 ASUS GPU Block brings the ultimate cooling performance with unique water block features to build stunning water-cooled systems.
Phanteks’ Glacier G40 ASUS GPU Block provides a high-performance water-cooling solution custom-designed for the latest ASUS GeForce RTX 4000 series cards. A transparent acrylic jet plate is positioned directly over the GPU die to ensure optimal heat transfer. The backplate is included with all models to provide a smooth integrated look while providing additional cooling to the back of the PCB. In addition, the full- cover copper cold plate directly cools all memory and power delivery components on the PCB with high-quality thermal pads.
The Glacier G40 ASUS GPU Block also introduces some new features, such as a new fitting location to allow for better tube routing, even in the most compact chassis. To improve stability, a GPU support bracket is added to connect the water block to the rear PCI bracket so that the GPU is mounted more securely.
Like all Phanteks’ Glacier products, the Glacier G40 ASUS GPU Block is made in Taiwan using only 100% copper, cast acrylic, anodized aluminum covers, and extremely durable Viton O-rings known from the automotive and aerospace industries. The integrated D-RGB lighting beautifully complements the water block and can synchronize with Phanteks’ D-RGB accessories and compatible motherboards.
The Glacier G40 ASUS GPU block will be available in Satin Black, Chrome and Matte White color finishes.
Discussion (4 replies)
Join Discussion →Wait they had a 4080 to design for! Cheaters! Where's mine! lol.
May be the same PCB layout - the block I have from Watercool works for FTW3 cards from the 3080 10GB to the 3090, for example.
These are not quite my style with all of that transparency and RGB, but the more the merrier.
It is great to have more options in full cover blocks.
It's too bad it's still a small enough customer base that water blocks rarely have detailed performance based reviews (with head to head performance and flow tests)
Yep and more than a few folks have speculated that some 3090 Ti and 4090 PCBs are the same so the 4080 would make sense too if true.
