Phanteks Releases Glacier G40 Water Blocks for GIGABYTE and MSI GeForce RTX 4090/4080 Series Graphics Cards
Image: Phaneks
Phanteks has announced the release of its Glacier G40 MSI and GIGABYTE GPU blocks, new water blocks designed specifically for MSI SUPRIM (X)/GAMING (X) TRIO and GIGABYTE AORUS MASTER/GAMING OC RTX 4090/4080 Series graphics cards. Capable of bringing the ultimate cooling performance with unique water block features to build stunning water-cooled systems, according to the company, all are available beginning today in three color finishes, including satin black, chrome, and matte white, starting at $249.99. A GPU support bracket that connects the block to the PCI bracket has been implemented for improved stability and to prevent sagging.
GLACIER G40 Gigabyte GPU Block supports:
  • GIGABYTE AORUS GeForce RTX 4090 MASTER 24G
  • GIGABYTE GeForce RTX 4090 GAMING OC 24G
GLACIER G40 Gigabyte GPU Block options:
  • SATIN BLACK €249.90 / £229.90 / $249.99
  • CHROME €269.90 / £244.90 / $269.99
  • MATTE WHITE €269.90 / £244.90 / $269.99
GLACIER G40 MSI GPU Block supports:
  • MSI GeForce RTX 4090 SUPRIM X 24G
  • MSI GeForce RTX 4090 SUPRIM 24G
  • MSI GeForce RTX 4090 GAMING X TRIO 24G
  • MSI GeForce RTX 4080 16GB SUPRIM X
  • MSI GeForce RTX 4080 12GB SUPRIM X
  • MSI GeForce RTX 4080 16GB GAMING X TRIO
  • MSI GeForce RTX 4080 16GB GAMING TRIO
GLACIER G40 MSI GPU Block options:
Image: Phanteks
From a Phanteks press release:
The Phanteks’ Glacier G40 MSI & GIGABYTE GPU Blocks provide a high-performance water-cooling solution custom-designed for the latest MSI & GIGABYTE GeForce RTX 4000 series cards. A transparent acrylic jet plate is positioned directly over the GPU die to ensure optimal heat transfer. The backplate is included with all models to provide a smooth integrated look while providing additional cooling to the back of the PCB. In addition, the full-cover copper cold plate directly cools all memory and power delivery components on the PCB with high-quality thermal pads. To improve stability, a GPU support bracket is added to connect the water block to the rear PCI bracket so that the GPU is mounted more securely.
Like all Phanteks’ Glacier products, the Glacier G40 MSI & GIGABYTE GPU Blocks are made in Taiwan using only 100% copper, cast acrylic, anodized aluminum covers, and extremely durable Viton O-rings known from the automotive and aerospace industries. The integrated D-RGB lighting beautifully complements the water block and can synchronize with Phanteks’ D-RGB accessories and compatible motherboards.
