GIGABYTE has launched its first AMD Radeon RX 7900 Series graphics cards in the form of the AORUS Radeon RX 7900 XTX ELITE 24G, Radeon RX 7900 XTX GAMING OC 24G, Radeon RX 7900 XTX 24G, Radeon RX 7900 XT GAMING OC 20G, and Radeon RX 7900 XT 20G.
Built on the AMD RDNA 3 architecture with advanced AMD chiplet design, all of these models will be available for purchase on December 13, 2022, according to GIGABYTE.
The AORUS ELITE graphics card features aerospace-grade PCB coating and ULTRA DURABLE certified components. The improved power phase design and precise power control deliver lower component temperature, less noise, and less signal interference. Moreover, the upgraded specially designed metal back plate provides a more durable structure that prevents bending and damage from long-term use. Also, the graphics card comes with a tailored anti-sag bracket that provides the optimal reinforcement and enhances the overall visual appearance. To deliver a better user experience, AORUS ELITE graphics cards provide customers with a 4-year warranty (requires online registration within 30 days of the purchase date) so that they can enjoy gaming and create content without any worry.
Radeon RX 7900 XTX|XT GAMING OC Series
The popular Radeon RX 7900 XTX GAMING OC 24G and Radeon RX 7900 XT GAMING OC 20G graphics cards focus on performance and stability, making them suitable for many different types of users. The GAMING OC graphics card uses the WINDFORCE cooling system. It features three unique blade fans with alternate spinning, a large vapor chamber that connects directly to the GPU, composite copper heat pipes, 3D active fans, and screen cooling to maximize heat dissipation. The WINDFORCE fans utilize graphene nano lubricant, which extends fan life by 2.1 times, delivering nearly the lifespan of the double ball bearing while providing quiet operation. Furthermore, the graphics card offers RGB lighting, allowing gamers to customize the RGB effects and colors via GCC software to create their own PC style. The GAMING OC graphics card is equipped with an upgraded metal back plate, a tailored anti-sag bracket and ULTRA DURABLE certified components, which not only provide a more durable structural design, but also allow the graphics card to deliver higher performance at lower temperatures.
GIGABYTE Radeon RX 7900 XTX|XT Series
The GIGABYTE Radeon RX 7900 XTX 24G graphics card is equipped with 6144 stream processors and 24GB of GDDR6 384-bit memory with 96MB of second-generation AMD Infinity Cache technology. The output includes an HDMI port, two DisplayPort 2.1 ports and a USB TYPE-C port. The system power supply requirement is 800 watts. The GIGABYTE Radeon RX 7900 XT 20G graphics card is equipped with 5376 stream processors and 20GB of GDDR6 320-bit memory with 80MB of second-generation AMD Infinity Cache technology. The output includes an HDMI port, two DisplayPort 2.1 ports and a USB TYPE-C port. The system power supply requirement is 750 watts.
“AORUS is also bringing back an upgraded version of GIGABYTE’S signature triple-ring RGB lights, RGB Halo, regarded as the RGB lighting leader for many AORUS fans and DIY enthusiasts,” the manufacturer added.
“This beloved feature takes advantage of the persistence of human vision and offers addressable lighting effects on the rotating fans. It will make every PC build glow in style. Gamers can also customize the RGB lighting through the GIGABYTE CONTROL CENTER (GCC) software.”
