Turtle Beach Announces Availability of VelocityOne Stand for Flight Simulation and Racing Simulation Setups
Image: Turtle Beach
Turtle Beach has announced the global availability of its VelocityOne Stand, a new accessory that completes what the company has described as its ultimate award-winning flight simulation setup, housing the VelocityOne Flight Universal Control System or VelocityOne Flightstick, along with the VelocityOne Rudder pedals, to deliver a modern flight simulation experience at home.
  • Adjustable Design: Utilizing quick-release clamps, the VelocityOne Stand allows for precision height, angle, and length adjustments, plus tilt adjustments for the upper and lower mounting platforms.
  • Solid Steel Build: A durable steel build keeps simulation accessories securely mounted, plus VelocityOne-specific and universal style mounting holes allow for permanent installation of simulation accessories.
  • Universal Compatibility: The VelocityOne Stand is built for the VelocityOne Flight Universal Control System, VelocityOne Flightstick, and VelocityOne Rudder pedals, and works with most other third-party yokes, racing wheels, rudder pedals, and racing pedals.
  • Fold-Flat Design: VelocityOne Stand folds flat without the need to remove any accessories, allowing you to keep your setup installed but stow it away conveniently.
  • Reversible: Versatile design lets you reverse the orientation of the main shaft depending on your preference.
  • Adjustable Rubber Feet: Anti-wobble rubber feet are adjustable to ensure the VelocityOne Stand stays firmly planted.
VelocityOne Stand has built-in quick release latches for adjusting the height, angle, and length to adapt to any player and environment. Additionally, the upper mounting platform tilts for proper yoke, stick, or wheel placement, and the lower platform can be similarly adjusted for rudder or racing pedals. The VelocityOne Stand’s reversible design allows it to be used facing either direction, and solid steel mounting platforms are predrilled to ensure a perfect fit. Anti-wobble, adjustable rubber feet keep the VelocityOne Stand firmly planted, and a convenient fold-flat design allows for stowing away easily without needing to unmount your accessories.
Turtle Beach has confirmed that its VelocityOne Stand is now available on www.turtlebeach.com and participating retailers for a $199.99 MSRP.
