NVIDIA GeForce RTX 4070 and GeForce RTX 4060 Ti Tipped with 200-Watt TGP
Image: NVIDIA
NVIDIA’s next GeForce RTX 40 Series graphics cards are the GeForce RTX 4070 and GeForce RTX 4060 Ti, according to a new report online that suggests two additional AD104 “Ada” GPUs are close to entering mass production. Both of these GPUs will feature a TGP of 200 watts, it’s claimed, although that specification could change. A 200-watt TGP would put the GeForce RTX 4070 and GeForce RTX 4060 Ti on par with the GeForce RTX 3060 Ti in that particular department.
From a Wccftech report:
[…] we have the NVIDIA AD104-250 and the AD104-251. The die used for the RTX 4070 Ti is the AD104-400-A1 so you can guess just how much of a cut-down chip we might be getting. What’s interesting is that the chip designation 251/250 makes it look like both will be very similarly configured though that remains to be seen.
[…] the AD104-250 GPU SKU will be the first to hit production in the second half of February followed by the AD104-251 SKU which will hit mass production by the second half of March. There’s currently no shelf date mentioned for each card but it is likely to be in the second half of 2023, around Computex 2023.
Previous leaks have suggested that the NVIDIA GeForce RTX 4070 will feature 5,888 CUDA cores, 12 GB of GDDR6X VRAM clocked at 21 Gbps, 36 MB of L2 cache, and a 250-watt TGP. It’s unclear how much this GPU will cost, but NVIDIA launched the GeForce RTX 3070 in October 2020 for $499, while the GeForce RTX 3060 Ti was launched just a few months later in December 2020 for $399.
