Corsair has announced the RMx SHIFT Series, a new lineup of ATX 3.0-certified power supplies that feature a different design than what enthusiasts might be accustomed to. According to images shared by the company, these new PSUs are unique in that they feature the DC connector panel on the side of the unit, something that Corsair says enables easier access to cables and simpler, cleaner cable management. The RMx SHIFT Series of fully modular 80 PLUS Gold-certified PSUs is available immediately from Corsair’s webstore and its worldwide network of authorized retailers and distributors in wattages from 750 to 1,200 watts.
From a Corsair press release:
The RMx SHIFT Series’ repositioned side panel (patent-pending) gives you a clear view and better access to all modular micro-fit connections, making connecting and maintaining your cables a breeze. Not only does this make attaching and detaching cables easy, it also means they won’t be bent or twisted as much to reach the connectors, resulting in less strain and a cleaner build.
Every model of RMx SHIFT is ATX 3.0 certified and PCIe 5.0 compliant for powering the latest cutting-edge systems, helping to improve overall system performance and reliability while providing the power needed to operate at the highest levels. With an included high-quality PCIe 5.0 12VHPWR GPU cable, the RMx SHIFT Series is ready for use with modern graphics cards such as the NVIDIA GeForce RTX 40 Series.
The RMx SHIFT Series comes equipped with all the features that PC builders have come to expect from the RMx name. Only connect the cables your system needs thanks to fully modular CORSAIR Type 5 Gen 1 micro-fit cables. A 140mm fluid dynamic bearing fan utilizes a specially calculated fan curve for high performance, low noise, and superior reliability, with support for Zero RPM fan mode for near-silent operation at low loads. 80 PLUS Gold and Cybenetics Gold-certified, the RMx SHIFT Series is rated for steady power output at up to 90% efficiency. 100% 105°C-rated Japanese electrolytic capacitors guarantee unwavering power delivery and long-term durability.
CORSAIR has tested the RMx SHIFT in all current CORSAIR cases to guarantee compatibility, and has already updated the online PC Builder database with the most popular third party cases. CORSAIR is hard at work verifying compatibility with most third party cases and will continue to add that information to the PC Builder database over the coming weeks. As a general guideline, a minimum clearance of 30mm of open space to the side of the bottom compartment is necessary to accommodate the side-positioned connector panel.
