GELID Debuts Its Ultimate AIO Liquid CPU Cooler Product Line with the Launch of 120mm and 240mm Coolers
Image: GELID
GELID has launched its Ultimate AIO Liquid CPU cooler product line with the debut of two models which are compatible with both AM5 and Intel LGA 1700 processors. GELID debuts the new line with the GELID Liquid 120 and Liquid 240 and each features a temperature display along with an infinite mirror effect on the copper 2600 RPM pump, an aluminum radiator, 4-pin PWM (750-1800 RPM) fan(s) which are listed with a noise level of 29.6 dBA and a maximum of airflow of 61.9 CFM. Both come with a 5-year warranty. The GELID 120 is available for $66.00 while the GELID 240 goes for $85.00.
Image: GELIID
From GELID
GELID Liquid 120 features a masterpiece of top-notch liquid cooling technologies. The premium-class high-density radiator, the silent Fans with Smart ARGB PWM, and the high-class water pump deliver ultimate cooling performance. The all-in-one cooling handles the latest requirements even the most powerful LGA 1700 from Intel and AM5 from AMD. The support of TDP over 240W makes the GELID Liquid 240 an overkill CPU AIO cooling solution for pro gamers and overclockers.
GELID 120 Specifications
Pump Specifications:
ARGB Connector:3 Pin
ARGB Voltage (V):5
Block Material:Copper
Pump Connector:3 Pin
Pump Dimension (mm):75 x 75 x 56
Pump RPM:2600
Radiator Dimension (mm):120 x 154 x 27
Radiator Material:Aluminium
TDP (W):max. 150
Tube:FEP sleeve
Warranty (years):5
Water Pump Voltage (V):12
Weight (g):850 (with mounting kits and fans)
Table: GELID
Fan Specifications:
Air Flow (CFM):max. 61.9
ARGB Voltage (V):5
Bearing:Hydro Dynamic
Current (A):0.2
DC Voltage (V):12
Fan Connector:4 Pin PWM
Fan Dimensions (mm):120 x 120 x 25
Fan Speed (RPM):750 – 1800
Life Time MTTF at 40°C (hr):50000
Noise Level (dBA):29.6
Static Pressure (mmAq):1.67
Table: GELID
GELID 240 Specifications
ARGB Voltage (V):5
Pump RPM:2600
Radiator Dimension (mm):120 x 276 x 27
TDP (W):max. 240
Tube:FEP sleeve
Warranty (years):5
Weight (g):1200 (with mounting kits and fans)
Table: GELID
Fan Specifications:
ARGB Voltage (V):5
Current (A):0.2
DC Voltage (V):12
Table: GELID
