Cooler Master Launches MasterFan Halo² Dual Loop LED Fans with Improved Performance and Aesthetics
Image: Cooler Master
Cooler Master has launched the MasterFan MF120 Halo², MasterFan MF120 Halo² White Edition, MasterFan MF140 Halo², and MasterFan MF140 Halo² White Edition, new case fans with RPM speeds of up to 2,050 RPM that continue the signature Dual Loop ARGB LED lighting of the original Halo fan but with improved cooling capabilities and lighting vibrancy. Thanks to a 10% increase in fan blade size, the new series pushes more airflow and provides stronger cooling performance, while fan noise is minimized courtesy of a Hybrid Frame Design and an updated Fan Control IC. The MF120 Halo² costs $24.99, while the MF140 Halo² costs $29.99. Both are available in 120 and 140 mm sizes, as well as black and white colorways.
“The MasterFan Halo² Series builds on the success of its predecessor and delivers even better performance and aesthetics,” said Jimmy Sha, CEO of Cooler Master. “We know how important it is for gamers and PC enthusiasts to have reliable, high-performing cooling solutions, and the MasterFan Halo² delivers on that promise with its enhanced design and features.”
MASTERFAN MF120 HALO² Product Sheet
MASTERFAN MF120 HALO² WHITE EDITION Product Sheet
MASTERFAN MF140 HALO² Product Sheet
MASTERFAN MF140 HALO² WHITE EDITION Product Sheet
From a Cooler Master press release:
The new Dual Loop LED Case Fans feature a 10% increase in fan blade size for improved airflow and cooling performance, while the hybrid frame structure ensures stability without compromising operational estate. The upgraded driver IC also enhances cooling performance while minimizing fan noise, with RPM speeds of up to 2050 RPM.
The MasterFan Halo² comes with Addressable RGB control, allowing for customization of every LED to fit any design needs. It will be available in 120mm and 140mm sizes, as well as black and white colorways. The MF120 Halo² will be available for $24,99 and MF140 Halo² will be available for $29,99.
