NVIDIA is planning to release two more GeForce RTX 40 Series GPUs in the form of the GeForce RTX 4060 Ti and GeForce RTX 4060 in May, according to new rumors that have surfaced online. The GeForce RTX 4060 Ti is said to feature a variation of the AD106 GPU and a TGP of 160 watts, while the GeForce RTX 4060 is said to feature the full AD107 GPU and a TGP of up to 115 watts. Their pricing remains unknown, but NVIDIA launched their predecessors, the GeForce RTX 3060 Ti and GeForce RTX 3060, for $399 and $329, respectively. The new GeForce RTX 4060 models will be preceded by the GeForce RTX 4070, which is slated for an April 13 launch, while the GeForce RTX 4070 Ti is available now starting at $799.99.
NVIDIA GeForce RTX 4060 Ti Rumored Specifications
- AD106-350-A1 GPU core (cut-down version of the AD106)
- PG190 SKU 361 PCB
- 4,252 CUDA cores
- 8 GB of GDDR6 memory (18 Gbps)
- 128-bit memory interface width
- 288 GB/s of memory bandwidth
- 32 MB of L2 cache
- 160-watt TGP
NVIDIA GeForce RTX 4060 Rumored Specifications
- AD107-400-A1 GPU (Full AD107 die)
- PG173 SKU 371 PCB
- 3,072 CUDA cores
- 24 MB of L2 cache
- 110- to 115-watt TGP
From a Wccftech report:
The NVIDIA GeForce RTX 4060 Ti & RTX 4060 graphics cards based on the Ada GPU architecture are expected to launch after the RTX 4070 which launches early next month on the 13th of April. This is going to be a full retail launch and our sources state that May is being targeted for both GPUs. […]
The [GeForce RTX 4060 Ti] is expected to utilize the PG190 SKU 361 PCB. Leaked PCB shots revealed that while the reference Founders Edition makes use of the standard 16-Pin 12VHPWR connector, the custom models will be free to use either standard 8-pin connectors or the newer 16-pin plugs. We have been told that it is much cheaper to just go with 8-pin connectors so that should be the target as AIBs want to maximize the production value of their designs. As for the TDP, the card will end up between 150-160W which is around 25% lower than its predecessor, the RTX 3060 Ti.
The NVIDIA GeForce RTX 4060 should end up with a 35% lower TGP than its predecessor, the RTX 3060 12 GB. While previous rumors pointed out the card using a PG190 PCB, our info suggests it would use the PG173 SKU 371 PCB design. It is likely that the PG190 variant is used by the FE and the PG173 is used by the reference AIC boards. Just like the RTX 4060 Ti, the Non-Ti variant will mostly rely on the standard 8-pin connectors and we will get some nice Mini-ITX variants of the card too, making for some truly efficient gaming PCs.
