Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory Review
Gaming Benchmarks
1080p Gaming
Shadow of the Tomb Raider
In Shadow of the Tomb Raider, the Intel XMP setup shined 239 FPS at 1080p which was 6 higher than the AMD EXPO setup. Overclocking the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory added a single FPS to the winnings.
Horizon Zero Dawn
The AMD EXPO setup won this round at 199 FPS which was 11 FPS higher than the Intel EXPO setup at both stock and overclocked speeds.
Watch Dogs: Legion
In Watch Dogs Lgion, we found the Intel XMP setup at 134 FPS which was 3 FPS higher than the AMD EXPO efforts. Overclocking added, you guessed it, 3 FPS to the Intel EXPO setup.
Cyberpunk 2077
In Cyberpunk 2077, the AMD EXPO setup eeks out a win at 148 FPS over the Intel AMP setup a single FPS slower than it. Overclocking the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory adds 4 frames to the stock side of things to push it ahead.
4k Gaming
Moving on to 4k performance, it’s a yawner – all platforms using the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory land at 98 FPS in Shadow of the Tomb Raider.
Horizon Zero Dawn
In Horizon Zero Dawn, the AMD EXPO platform takes the win at 96 FPS by beating the Intel XMP set up by a single FPS. Overclocking the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory ties the match back up.
Watch Dogs: Legion
In Watch Dogs Legion at 4k, it’s a snoozer with all contestants tying at 66 FPS.
Cyberpunk 2077
In Cyberpunk 2007, the Intel XMP setup yields 49 FPS with the AMD EXPO setup two behind at 47 FPS. Overclocking the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory makes no difference to the overall performance.
Performance
Aesthetics
Price Value
5
From a functionality perspective sporting both XMP and EXPO profiles, the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory worked its way through our test suite on both Intel and AMD platforms with ease. Its RGB capabilities give it a good look to pair with its performance. The only issue we have is with its pricing at the time of publication, which lands north of its competition for comparable performance and features.
