Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory Review
Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory installed in a system
Today we reviewed the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory kit and showcased its performance on an Intel 13900K based platform running at its XMP configuration and overclocked along with an AMD 7900X-based platform running at its EXPO configuration. The kit includes 2x16GB DDR5-6000MHz sticks with its XMP and EXPO profiles set to 34-38-38-76 at 1.3V. The Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory RGB bling is able to be controlled by your favorite motherboard manufacturer’s RGB center.
From an overall perspective, the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory was a solid performer and did what we asked it to do. From the memory kits we’ve had in-house, most do not have both XMP and EXPO profiles loaded, so having both in the same kit is a great benefit.
Putting it all together, the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory sports an MSRP (and current e-tail price) of $149.99 which is significantly lower than this caliber of DDR5 was just a few months ago, however, that’s also significantly higher than the current market price for DDR5-6000 C-mid-30’s that we’re seeing starting as low as $115.
Is the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory a capable product worth your hard-earned dollars? Absolutely! However, based on the pricing at the time of publication, there may be better options out there if it fits your targeted aesthetic.
Performance
Aesthetics
Price Value
5
From a functionality perspective sporting both XMP and EXPO profiles, the Lexar ARES RGB DDR5 32GB (2x16GB) 6000MHz Memory worked its way through our test suite on both Intel and AMD platforms with ease. Its RGB capabilities give it a good look to pair with its performance. The only issue we have is with its pricing at the time of publication, which lands north of its competition for comparable performance and features.
