PNY Announces XLR8 Gaming VERTO EPIC-X RGB and VERTO Dual Fan GeForce RTX 4060 Series Graphics Cards
Image: PNY
PNY has announced that its new family of GeForce RTX 4060 Series graphics cards will include nine models under the XLR8 Gaming VERTO EPIC-X RGB and VETRO Dual Fan brands. PNY’s GeForce RTX 4060 Ti 8 GB options will be available from May 24 via BestBuy.com, Amazon.com, and other e-tail partners starting at $399.99, while the GeForce RTX 4060 Ti 16 GB and GeForce RTX 4060 options will be coming soon, starting at $499.99 and $299.99, respectively. The XLR8 models feature customizable LEDs, all of which can be controlled via PNY’s VelocityX software.
PNY GeForce RTX 4060 Ti (16 GB)
PNY GeForce RTX 4060 Ti (8 GB)
PNY GeForce RTX 4060 (8 GB)
From a PNY press release:
PNY GeForce RTX 4060 Ti’s
The GeForce RTX 4060 Ti models expand PNY’s memory variety with 16GB and 8GB options. Enjoy remarkable cooling even when running resource-heavy games and content creation with two 90mm fans on the impeccably crafted compact dual fan design and three 90mm fans on XLR8 gaming triple fan designs. GeForce RTX 4060 Ti 16GB and 8GB VERTO models feature a sleek aluminum backplate to protect sensitive components and air vents to provide additional heat dissipation. Three copper heat pipes on the XLR8 Gaming VERTO GPUs and two copper heat pipes on the PNY VERTO GPU, pair with a copper base offering the ultimate cooling potential in the most compact PNY design to date. The compact dual slot design and powerful single 8-pin power connector offers expanded compatibility for a larger range of computer chassis without compromising performance.
The GeForce RTX 4060 models are produced with the same high-precision craftsmanship and comparable features as their Ti counterpart. GeForce RTX 4060 GPUs are designed with two 90mm fans on the PNY VERTO model and three 80mm fans on XLR8 Gaming triple fan designs to maximize cooling in conjunction with two copper heat pipes and the copper base. GeForce RTX 4060 models continue to offer expanded compatibility with a powerful single 8-pin power connector on PNY’s compact dual slot design. Experience additional heat dissipation with maximized airflow through meticulously cut air vents on the durable aluminum backplate.
NVIDIA DLSS 3 Gaming Powered by AI
Get the best performance boost using DLSS 3, built with advanced AI algorithms that use predictive models to seamlessly generate frames based upon previous and current frames, producing a hyper-realistic graphic experience while using NVIDIA Reflex to mitigate overall system latency. NVIDIA GeForce Game Ready Drivers deliver the latest updates to your PC. DLSS 3 delivers a massive leap in performance by generating high quality frames. Turn DLSS 3 on and experience more frames in over 300 popular gaming titles, and growing.
Overclocking and ARGB Customization
Take your rig to the next level with ARGB lighting control and overclocking through PNY’s VelocityX software. The PNY XLR8 Gaming RTX 4060 Ti GPUs are equipped with 13 customizable LEDs and the PNY XLR8 Gaming RTX 4060 GPUs are equipped with 6 customizable LEDs featured on the graphics card top edge, unlocking all new RGB effects with remarkable individual RGB control. Level-up and illuminate your system with brilliant ARGB lighting, fine-tune performance parameters, and monitor critical stats like core and memory clocks, core temperature, fan speed, RGB lighting and more.
