AMD Radeon RX 7600 Leak Reveals 2,625 MHz Boost Clock, Increased Power Consumption, and $269 Price Tag
Image: AMD
AMD has sent out an email to press and influencers that can confirm its next RDNA 3 graphics card, the Radeon RX 7600, will launch on May 25 for $269. This is $130 cheaper than the NVIDIA GeForce RTX 4060 Ti (8 GB), which starts at $399. Additionally, HD Tecnologia has leaked the full specifications for the Radeon RX 7600 as part of a report that suggests ASUS and ASRock will be using old cooler designs for their custom models, revealing 2,048 Stream Processors, a boost clock of up to 2,625 MHz, 8 GB of GDDR6 memory, and other key features. Power consumption of the Radeon RX 7600 is up from the previous generation, however, with an additional chart showing a 165-watt TBP (vs. a 132-watt TBP) and a recommended power supply wattage of 550 watts (vs. 450 watts) for AMD’s new GPU.
From an HD Tecnologia post (machine translation):
The GPU will offer 8 GB GDDR6 of video memory on a 128-bit interface, providing 288 GB/s of bandwidth, just like the RTX 4060 Ti. The Radeon RX 7600 will be limited to PCIe Gen 4 with 8 lanes, previous models the RX 66xx series.
As for the frequencies, the mid-range AMD RDNA 3 GPU comes with a frequency of 2250 MHz and going up to 2655 MHz.
Since the Radeon RX 6600 uses the Navi 23 XL GPU and the RX 6600 XT uses the Navi 23 XT, it could be that AMD is preparing a Radeon RX 7600 XT. In the case of the RDNA 2 GPU, the release difference was two months.
Image: AMD/HD Tecnologia
