Giga Computing, the subsidiary of GIGABYTE that describes itself as an industry leader in high-performance servers, has expanded its series of BRIXs mini PCs with a handful of new models that feature AMD Ryzen 7030U Series processors. The latest collection is headlined by the GB-BRR7H-7730, an ultra-compact, lower-power mini PC that features an 8-core Ryzen 7730U CPU (4.5 GHz), integrated Radeon graphics, and support for up to 32 GB of DDR4 memory.
- Giga Computing, a subsidiary of GIGABYTE and an industry leader in high-performance servers, workstations, and mini-PCs, announced a newly designed ultra-compact, mainstream mini-PC for the GIGABYTE BRIXs lineup that adopts AMD Ryzen 7030 series processors.
- The new BRIXs delivers powerful computing that fits perfectly in any IoT deployment, whether for office use, education use, home use, digital signage, medical care, or KIOSK.
- The most recent generation of mainstream BRIXs products in 2023 adopt an all-new chassis design that increases computing performance without increasing the size of the chassis.
- With AMD Ryzen 7030U processors, BRIXs makes its high-performance mainstream series even better and betters prior 10th Gen Intel mobile processors.
- The new mobile processors – AMD Ryzen 7030U series with AMD Zen3 architecture and 7nm process – advanced its chip performance so users can get dedicated tasks done faster and easier.
Giga Computing BRIXs Mini PC Specifications
Giga Computing BRIXs Mini PC Models
From a GIGABYTE press release:
With AMD Zen3 architecture and TSMC 7nm process, AMD advanced its high-performance, efficient mobile processors for the mobile market to multitask and stay entertained. Even while adopting a compact size, all new mainstream BRIXs still delivers powerful computing that fits perfectly in any IoT deployment, whether for office use, education use, home use, digital signage, medical care, or KIOSK.
Upgrade to the Future; Minimalism Meets Power
The most recent generation of mainstream BRIXs products in 2023 adopt an all-new chassis design. Computing performance has increased, but the design does not require an increase in the size of the chassis. Its appearance has curved, soft, and twisted lines with a liveliness that makes it very unobtrusive. By the way it was assembled and layered, and designing oblique angles around the base, a sense of simplicity is created to achieve a lightweight design. This allows users to enjoy ultimate computing performance while also having a stylish and elegant product.
The New Generation of AMD Ryzen 7030U Series Processor
With AMD Ryzen 7030U processors, BRIXs makes its high-performance mainstream series even better, and it betters prior 10th Gen Intel mobile processors. The new mobile processors – AMD Ryzen 7030U series with AMD Zen3 architecture and 7nm process, AMD advanced its chip performance so users can get dedicated tasks done faster and easier. In addition to that, more efficiency cores make better multi-tasking with smart power management, so that users can still stay on the go with great battery life.
These advanced processors also deliver stunning graphics and unparalleled connectivity, providing an immersive display and lightning-fast wired and wireless connections. You can scale BRIXs performance from systems with AMD Ryzen R3 7330U that has up to 4 cores and a turbo frequency of 4.3GHz to AMD Ryzen R7 7730U with up to 8 cores and a turbo frequency of D 4.5 GHz. Moreover, the product shines with AMD RZ608 Wi-Fi 6 (Gig+), AMD Radeon Graphics, and enhanced image processing to enjoy a balance of performance and value for the essential BRIXs that’s right for you. Compared to the previous BRIXs generation with 10th gen Intel mobile processors, the new generation can easily get significant performance uplift with up to 70% faster single-threaded performance and 140% better multi-threaded performance. With the above benefits, users can experience speed and incredible battery life to work, play, create, collaborate, and stream from anywhere.
Offering All the Latest Technologies You Want
The mainstream BRIXs features all the latest technologies you want. Enhanced by the latest AMD Radeon Graphics, new BRIXs offers optimized graphics performance for users to experience greater 4K details. The new AMD Radeon Graphics engine supports HDMI 2.0b and Mini DP 1.4 display outputs, and they can be used at the same time on multiple monitors that support up to 3840×2160 @ 60Hz resolution, providing excellent computing performance on 4 displays (from 2x HDMI and 2x USB type C with DP alt mode) for either video playing, video editing, home use, or commercial applications. To better manage cables, all the display connectors are found on BRIXs’ backside for a cleaner environment. In addition to above features, all new BRIXs can support Type-C connectors with speeds of 5 Gb/s as well as M.2 SSD and 2.5” HDD/SSD support to deliver a snappy user experience. Of course, if you need more storage capacity, you can choose our HS version which enables additional dual M.2 slots to expand storage. Furthermore, BRIXs continues to support VESA mounting to make a simple and effective way to turn any VESA-compliant display or TV into a full-featured PC or digital signage unit.
The Perfect Fit for Any Space
Challenging the essence of how we define a mini-PC, GIGABYTE has developed an ultra-compact, low power PC with impressive performance in a minimalistic design. Ideal for a broad range of computing applications for home, schools, or office, BRIXs expounds sheer simplicity and convenience. With a broad choice of AMD mobile processors covering the entire performance spectrum, BRIXs sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, office, or school, or as a digital signage unit.
