GIGABYTE Launches AORUS GeForce RTX 4070 Ti XTREME WATERFORCE Graphics Cards
Image: GIGABYTE
GIGABYTE has introduced two new NVIDIA GeForce RTX 4070 Ti water-cooled graphics cards in the form of the AORUS GeForce RTX 4070 Ti XTREME WATERFORCE 12G and AORUS GeForce RTX 4070 Ti XTREME WATERFORCE WB 12G. They feature RGB Fusion, a protection metal backplate, aerospace-grade PCB coating for dust and moisture protection, Ultra-Durable top-grade components, and extended warranty for registered members, and they’re also certified by GIGABYTE’s GPU Gauntlet sorting technology, which “guarantees the higher overclocking capability in terms of excellent power switching,” according to the company.
The AORUS WATERFORCE all-in-one water-cooled graphics card provides a convenient installation solution for high-end gamers, as the water-cooling radiator and pump are pre-assembled. This graphics card offers exceptional cooling performance, featuring a 240mm radiator and dual 120mm fans, effectively reducing the operating temperature and extending the lifespan of the card.
To satisfy the demand for gamers, the AORUS WATERFORCE graphics card incorporates RGB Fusion lighting design. Not only do the front, side, and backplate of the card showcase lighting effects, but the two 120mm fans on the water-cooling radiator also feature RGB lighting. Through software control, users can synchronize and customize the lighting effects across different areas to match their personal style.
In addition, the AORUS WATERFORCE graphics card utilizes FEP as the material for the water pipes, ensuring exceptional durability and leak resistance to prevent any water loss and maintain long-term cooling efficiency. The pipes are further encased in braided sleeve, enhancing both the cooling performance and visual design of the graphics card.
The AORUS WATERFORCE open-loop water-cooled system is the ideal choice for PC enthusiasts who value personal style. AORUS optimizes the spacing between the micro fins to maintain stable water flow velocity and effectively dissipate the heat generated by the graphics card, ensuring smooth and unobstructed water channels. The sunk-designed copper micro fins shorten the heat conduction path of the graphics card, allowing for rapid transfer of heat to the water channels and improving overall cooling efficiency.
Additionally, the system is equipped with the patented “Leak detection” technology. In the event of a leak, the graphics card immediately alerts users by flashing lights, allowing them to shut down their system promptly and avoid any further damage caused by the leak.
Replacing an air-cooled graphics card with a water-cooled kit on your own not only voids the warranty but also presents challenges in finding suitable liquid cooling components. GIGABYTE provides a quality assurance with certified overclocked GPUs and professionally assembled graphics cards, allowing gamers to enjoy the pleasure without any concerns about installation or quality issues. In addition, both the front and back of the graphics card showcase various stunning RGB lighting effects, making it the centerpiece of any PC build.
The exceptional performance of the AORUS graphics cards is attributed to their power design and the ULTRA DURABLE certified components. These components enable the graphics card to deliver high performance while maintaining lower operating temperatures, ensuring stability and reliability. Both AORUS WATERFORCE graphics cards feature aerospace-grade PCB coating for dust and moisture resistance, providing protection against water droplets and minimizing the risk of damage. To deliver a better user experience, the AORUS WATERFORCE graphics cards provide to customers a 4-year warranty (requires online registration within 30 days of the purchase date).
