ASUS Announces ROG Strix GeForce RTX 4060 Ti (16 GB) with RGB Tail Lights
Image: ASUS
ASUS has announced that the ProArt GeForce RTX 4060 Ti (16 GB) and Dual GeForce RTX 4060 Ti (16 GB) will be joined by a third option in the form of the ROG Strix GeForce RTX 4060 Ti (16 GB). This is a “cyberpunk-styled” graphics card that features a 3.1-slot design, a relatively shorter length of 311.4 mm, a single 8-pin power connector, and a boost clock of up to 2,565 MHz. Users will also find a ring of ARGB lights at one end.
Aside from the VRAM increase, the ROG Strix GeForce RTX 4060 Ti 16GB is broadly similar to the previously announced 8GB variant. This cyberpunk-styled card offers a 3.1-slot design that’s only 311.4mm long for easy compatibility with a wide range of cases. It only requires a single 8-pin power connector, too, making it a drop-in upgrade for a wide range of gamers.
These compact dimensions still leave plenty of surface area on its MaxContact heatsink for airflow. Three of our new 11-blade Axial-tech fans, which can push 21% more air volume than our last-gen models, deliver a stream of cooling air. Additionally, a massive vented backplate gives heat another pathway to exhaust from your PC. 0dB technology keeps your card completely silent under lighter workloads.
Going with Strix gives you the premium package of extra features. Choose between performance and quiet modes with a Dual BIOS switch, connect your PC case fans to two FanConnect II headers, and light up your rig with a ring of ARGB tail-lights compatible with Aura Sync. Meanwhile, reliable power delivery and time-tested build quality through our Auto-Extreme manufacturing process help ensure this card will power your gaming experiences for years to come.
