Those looking to upgrade their PC CPU cooling solution have more options as Lian Li launches its updated GALAHAD II TRINITY series AIOs. The GALAHAD TRINITY line has been upgraded with a new copper plate design featuring a straightened pathway to reduce turbulence for improved cooling. Other changes to the pump include a larger impeller, a faster motor, and a revised fin thickness for better diffusion of the coolant over the copper plate surface.
The GALAHAD TRINITY II series is available in two tiers, standard and performance, and each in either 240mm or 360mm sizes in black or white. Both also include three interchangeable pump covers for further customization along with ARGB daisy-chainable fans. The performance line upgrades the AIO even further with a 32mm thick radiator with 19 FPI and 4200 rpm pump vs a 27mm thick radiator with 20 FPI and 3200 rpm pump of the standard model. Both come with a 5-year warranty and are compatible with most current Intel/AMD CPUs.
Pricing is expected to be as follows:
| Pricing | |||
| GALAHAD II TRINITY | GALAHAD II TRINITY SL-INF | GALAHAD II TRINITY PERFORMANCE | |
| 240 White | $119.99 | $159.99 | – |
| 240 Black | $119.99 | $159.99 | – |
| 360 White | $149.99 | $189.99 | $169.99 |
| 360 Black | $149.99 | $189.99 | $169.99 |
GALAHAD TRINITY II
| PRODUCT NAME | GALAHAD II TRINITY | |||
| MODEL | GA2T36B | GA2T36W | GA2T24B | GA2T24W |
| TYPE | 360mm | 240mm | ||
| COLOR | Black | White | Black | White |
| PUMP SPEED | 3200 RPM | |||
| RADIATOR FINS | Single wave | |||
| RADIATOR SIZE | 397.5 x 119.2 x 27mm | 277.5 x 119.2 x 27mm | ||
| PUMP SIZE | 74 x 74 x 69mm | |||
| INCLUDED PUMP BLOCK CAPS | Dazzle Mode,Sink Hole, Duo-Infinity | |||
| FAN SIZE | 120 x 120 x 25mm | |||
| FAN SPEED | 2450 RPM (Max.) | |||
| STATIC PRESSURE | 3.66 mmH2O (Max.) | |||
| AIRFLOW | 89.1 CFM (Max.) | |||
| ACOUSTIC NOISE | 35.4 dB(A) | |||
| BEARING TYPE | Fluid Dynamic Bearing (FDB) | |||
| COMPATIBLE CPU SOCKETS | Intel: LGA 1700 / 1200 / 115x AMD: AM5 / AM4 | |||
| WARRANTY | 5 years | |||
The GALAHAD TRINITY is available for preorder from Newegg now per Lian Li’s YouTube page.
GALAHAD TRINITY II Performance
| PRODUCT NAME | GALAHAD II TRINITY PERFORMANCE | |
| MODEL | GA2P36B | GA2P36W |
| TYPE | 360mm | |
| PUMP SPEED | 4200 RPM | |
| RADIATOR FINS | Double wave | |
| RADIATOR SIZE | 396 x 130 x 32mm | |
| PUMP SIZE | 74 x 74 x 79mm | |
| INCLUDED PUMP BLOCK CAPS | Dazzle Mode, Sink Hole, Duo-Infinity | |
| FAN SIZE | 120 x 120 x 28mm | |
| FAN SPEED | L: 2300 RPM (Max.) H: 3000 RPM (Max.) | |
| STATIC PRESSURE | L: 4.08 mmH2O (Max.) H: 6.99 mmH2O (Max.) | |
| AIRFLOW | L: 81.54 CFM (Max.) L: 108.29 CFM (Max.) | |
| ACOUSTIC NOISE | L: 32.1 dB(A) H: 39.9 dB(A)) | |
The GALAHAD TRINITY Performance is available for preorder from Newegg now per Lian Li’s YouTube page.
