AMD Radeon GPU Idle Power Draw Can Be Reduced Dramatically by Enabling VRR
Image: AMD
ComputerBase has shared new tests that suggest idle power draw in AMD RDNA 2 and RDNA 3 GPUs can be reduced dramatically simply by enabling Variable Refresh Rate (VRR). The Radeon RX 7900 XTX, in particular, draws up to 81% and 71% less idle power in single- and dual-monitor configurations with VRR, according to a table of measurements that the publication shared. “High idle power has situationally been observed when using select multi-display setups with mixed high-resolution and high refresh rate displays on Radeon RX 7000 series GPUs,” AMD continues to warn in its driver release notes.
AMD Radeon Power Measurements
4K144
desktop idle
4K144
dual monitor
4K144
window movement
4K144
YT, SDR, 60fps
4K144
YT, HDR, 60fps
Radeon RX 6700 XT
Old measurement
34 watts34 watts43 watts40 watts45 watts
Radeon RX 6700 XT
New measurement
8 watts
(-76 percent)
34 watts
(+-0 percent)
41 watts
(-5 percent)
38 watts
(-5 percent)
43 watts
(-4 percent)
GeForce RTX 3060 Ti
old measurement
18 watts24 watts43 watts27 watts42 watts
GeForce RTX 3060 Ti
New measurement
17 watts
(-5 percent)
24 watts
(+-0 percent)
38 watts
(-12 percent)
28 watts
(+4 percent)
36 watts
(-14 percent)
Arc A770
Old measurement
44 watts46 watts56 watts59 watts69 watts
Arc A770
New measurement
48 watts
(+9 percent)
50 watts
(+9 percent)
62 watts
(+11 percent)
59 watts
(+-0 percent)
66 watts
(-4 percent)
Radeon RX 6800 XT
Old Measurement
43 watts43 watts54 watts49 watts52 watts
Radeon RX 6800 XT
New measurement
9 watts
(-79 percent)
43 watts
(+-0 percent)
45 watts
(-17 percent)
47 watts
(-4 percent)
51 watts
(-2 percent)
GeForce RTX 3080
old measurement
21 watts23 watts50 watts33 watts48 watts
GeForce RTX 3080
New measurement
24 watts
(+14 percent)
31 watts
(+35 percent)
45 watts
(-10 percent)
34 watts
(+3 percent)
43 watts
(-11 percent)
Radeon RX 7900 XTX
Old measurement
104 watts105 watts111 watts72 watts109 watts
Radeon RX 7900 XTX
New measurement
20 watts
(-81 percent)
30 watts
(-71 percent)
71 watts
(-36 percent)
68 watts
(-5 percent)
75 watts
(-31 percent)
GeForce RTX 4080
old measurement
16 watts25 watts36 watts26 watts38 watts
GeForce RTX 4080
New measurement
20 watts
(+25 percent)
28 watts
(+12 percent)
36 watts
(+-0 percent)
27 watts
(+4 percent)
40 watts
(+5 percent)
The new results of the power consumption measurements on the Windows desktop are a real surprise. The fact that all AMD graphics cards require massively less electrical power on this Windows desktop depending on the scenario by activating Adaptive Sync in the driver, but not in Windows for the Windows desktop, was not expected and has not been confirmed to date explain, but the numbers don’t lie. AMD has yet to respond.
