PowerColor Unveils Red Devil AMD Radeon RX 7800 XT with 16 GB of GDDR6 Memory
Image: PowerColor
PowerColor has hit the publish button early for the Red Devil AMD Radeon RX 7800 XT, confirming that red team will, in fact, be launching at least one new RDNA 3 graphics card for desktop users shortly. According to a list of specifications that can be found at the bottom of the listing, this new graphics card from PowerColor will feature 16 GB of GDDR6 memory, putting it closely in line with the Radeon RX 7900 GRE, including 3,840 Stream Processors. The Red Devil AMD Radeon RX 7800 XT also appears to boost up to 2,565 MHz in OC mode.
PowerColor Red Devil AMD Radeon RX 7800 XT Features
  • Metal Reinforced Backplate
  • Dual BIOS
  • High Quality 14-Layer PCB Design
  • DrMOS with IMON Digital Monitoring
  • Optimum Heatpipe Arrangement
  • Personalized ARGB Lighting Effect
  • Ring-fan Blade Design
PowerColor Red Devil RX 7800 XT embraces an upgraded triple ringed-fan cooling solution (100 x 100 x 100mm), a set of 8 x 6φ heatpipes running through the heatsink, and a sleek copper plate directly touching the GPU while covering VRAM to rapidly transfer the heat; it also utilizes high quality PCB that comes with the 11+3+1+2+1 phase VRM design, and DrMOS with IMON real-time digital monitoring built in, all together to guarantee the optimum cooling efficiency and stability when pushing to the limits. Red Devil is designed to seize every victory in the game.
Image: PowerColor
Image: PowerColor
