ID-COOLING Announces Space LCD AIO Liquid CPU Cooler Lineup Which Allows Users to Upload MP4/GIFs to the Pump LCD Screen
Image: ID-COOLING
CPU AIO Pump LCD displays are continuing to evolve as ID-COOLING announces the availability of its upcoming Space LCD lineup. ID-COOLING has been manufacturing CPU and VGA cooling solutions for just over 10 years now and these latest coolers feature a stylish ARGB fan design along with an upgraded pump motor including its new LCD screen, premium sleeved tubing which includes clips for easy management, and premium 27mm thick radiators for optimal cooling.
The ID-COOLING SPACE LCD series will be available in 240 mm or 360 mm sizes and in either black or white. The pump LCD screen is 2.1 inches in diameter and the ARGB fluid-dynamic bearing fans, which feature a thin stripe around their frame, are 120x120x27 mm. ID-COOLING says that its Space Control software makes it easy for users to upload their MP4/GIFs, or other custom settings, to the pump LCD screen. The Space Software solution is also able to obtain data from the BIOS for the display. The SL lineup is said to arrive in Asia in September and then globally in October.
Image: ID-COOLING
Specifications (Black 360mm):
LCD SCREEN
  • Dimension: 2.1 inch
  • Resolution:480×480
  • Backlight: 600cd/m²
  • Color:24-bit, 16.7 million
Compatibility and Other Details
  • Intel: LGA2066/2011/1700/1200/1151/1150/1155/1156
  • AMD: AM5/AM4
  • TDP: 350W
  • Radiator Dimension: 397×120×27mm
  • Radiator Material: Aluminum
  • Tube Material: Premium Sleeved
  • Tubing Tube Length: 465mm
  • Waterblock Dimension: 76x76x58mm
  • Cold Plate Material: Copper
  • Pump Current: 0.36A Max.
  • Pump Speed: 0 – 2100RPM±10% / *0 – 2500RPM±10%
  • Pump Bearing: Ceramic Bearing
  • Pump Life Expectancy: 50,000 Hrs
  • Pump Noise Level: 25dB(A)
  • Fan Dimension: 120×120×27mm
  • Included Fans: 3pcs
  • Fan Speed: 500~2000±10%RPM
  • Max. Air Flow: 78CFM
  • Max. Static Pressure: 2.68mmH2O Noise 29.9dB(A)
  • Max. Rated Voltage: 12VDC Operating Voltage 10.8~13.2VDC
  • Started Voltage: 7VDC
  • Rated Current: 0.25A
  • Power Input: 3W
  • Bearing Type: Fluid Dynamic Bearing
  • Connector: 4Pin PWM
MSRP (per TechPowerUp):
  • SL240 BLACK $139.99.
  • SL240 WHITE $139.99.
  • SL360 BLACK $179.99.
  • SL360 WHITE $179.99.
