Acer Launches Low-Cost 4K 150 Hz HDR400 IPS 28″ Gaming Monitor Featuring AMD FreeSync Premium VRR
Image: Acer
Those on a budget have a new option for a 4K gaming display as Acer launches the low-cost Nitro XV282K V3 for $429.99. This new display features a 28-inch 16:9 IPS HDR400 (400 nits) panel with an overclock 150 Hz refresh rate, 1 ms GTG response time, and support for VRR with AMD FreeSync Premium via HDMI 2.1 or DP 1.4. It has a color gamut of 90% DCI-PC, 1.07 billion colors, and a 10-bit color depth (8-bit+FRC). Other features include a stand with swivel and height adjustment, 2x 2W speakers, a headphone jack, an anti-glare screen, Display 1.4, and HDMI 2.1 ports.
Technical Specifications (via official page):
  • Viewable Screen Size: 28″
  • Screen Mode: 4K UHD
  • Panel Technology: In-plane Switching (IPS) Technology
  • Response Time: 1 ms GTG
  • Aspect Ratio: 16:9
  • Pixel Pitch:6.3 mil
  • Horizontal Viewing Angle: 178°
  • Vertical Viewing Angle: 178°
  • Backlight Technology: LED
  • Mount Type: Wall Mountable
  • Features: VESA DisplayHDR 400
  • Screen Size Class:28″
  • Maximum Adjustable Height: 5.12″
  • Swivel Angle: -360° to 360°
  • Tilt Angle: -5° to 35°
  • Adjustable Stand Height: Yes
  • Active Display Area (mm): 621×341
  • Screen Surface: Anti-glare
  • Cover Glass: No
  • Frequency (Horizontal/Vertical): HDMI 2.1:30KHz-335KHz/48Hz-150Hz, HDMI 2.1:30KHz-335KHz/48Hz-150Hz, DisplayPort 1.4:335KHz/48Hz-150Hz, DisplayPort 1.4:335KHz/48Hz-150Hz
  • Audio Speakers: Yes
  • Speaker Output Power: 2 W
Physical Characteristics
  • VESA Mount Compatible: Yes
  • VESA Mount Standard: 100 x 100
  • Color: Black
  • Height: 14.6″
  • Width: 25″
  • Depth: 2.9″
  • Height with Stand: 22.68″
  • Width with Stand: 25.04″
  • Depth with Stand: 10.59″
  • Weight (Approximate): 11.64 lb
  • Weight with Stand (Approximate): 16.80 lb
Video
  • Maximum Resolution: 3840 x 2160
  • Color Supported: 1.07 Billion Colors
  • Color Depth: 8-bit+FRC (10-bit with Dithering)
  • Dynamic Contrast Ratio: 100,000,000:1
  • Brightness: 400 Nit
  • Tearing Prevention Technology: AMD FreeSyncâ„¢ Premium (DisplayPort/HDMI)
  • Color Gamut: 90% DCI-P3
  • Native Contrast Ratio: 1,000:1
  • Overclock Refresh Rate: 150 Hz
Miscellaneous
  • Package Contents: 1 x Nitro XV282K V3 Widescreen Gaming LED Monitor, 1 x Power Cord (US), 1 x HDMI Cable
  • Environmentally Friendly: Yes
  • Environmental Certification: MPR II
  • Interfaces/Ports: HDMI Version 2.1, Headphone, DisplayPort Version 1.4
  • Standby Power Consumption (Energy Star): 500 mW
  • Off-Mode Power Consumption (Energy Star): 300 mW
