CableMod Releases Updated 12VHPWR 90-Degree Angled Adapter with CEM 5.1 Female Connector
Image: CableMod
When will people stop complaining about CableMod adapters melting their GeForce RTX 4090 and other pricey NVIDIA GPUs? Maybe soon, as the company has released a new version of its 12VHPWR 90-Degree Angled Adapter that’s been updated with the new CEM 5.1 female connector—a new design overseen by PCI-SIG that features sense pins with a more substantial offset (.45 mm vs. 1.7 mm), implemented to reduce the chances of what some fear could be a dead GPU, or, worse, a house fire. CableMod’s new adapters are available in Black, Gold, Purple, Pink, and other colors for $39.90.
CableMod 12VHPWR 90-Degree Angled Adapter Features
  • Slim Profile
    • Our 12VHPWR 90 Degree Angled Adapter only protrudes 21mm from your graphics card, which means increased space and more clearance between your GPU and your side panel. This enables installation of super wide cards in more narrow chassis.
  • Zero Bending
    • Unlike 90 degree cable connectors, our angled adapters utilize a reinforced PCB design to achieve an angled connection. No wire bending ensures full contact with all cable terminals, and zero risk of thermal issues through excessive wire and terminal stress from tight bending radii.
  • Multi-Layered Cooling Solution
    • To ensure peak performance, our angled adapters use a 2oz copper PCB with applied copper foil to aid heat dissipation. Combined with a thermal pad and a quality aluminum shell, this multi-layered design helps keep things cool, even under continuous loads.
  • Two Variants
    • The CableMod 12VHPWR 90 Degree Angled Adapter comes in two variants, making sure there’s a solution for graphics cards no matter which 12VHPWR power port orientation they have. For those with extra tight space requirements, a 180 Degree Angled Adapter, which routes the cable above the graphics card, is also available.
  • Awesome Styling
    • No matter which variant you choose, this 12VHPWR 90 Degree Angled Adapter looks great with its sleek styling and unobtrusive design. Available in multiple colors, there’s sure to be an adapter that matches the theme of your build.
Compatibility List
  • AORUS 4070 Ti MASTER (backplate side)
  • AORUS 4080 MASTER (backplate side)
  • AORUS 4090 MASTER (backplate side)
  • ASUS Strix 4080 (cooler side)
  • ASUS Strix 4090 (cooler side)
  • ASUS TUF 4070 Ti (cooler side)
  • ASUS TUF 4080 (cooler side)
  • ASUS TUF 4090 (cooler side)
  • EK Quantum Vector2 RTX 4090 FE (without active backplate) (backplate side)
  • EK Quantum Vector2 Strix/TUF RTX 4090 (cooler side)
  • GIGABYTE 4070 Ti Gaming OC (backplate side)
  • GIGABYTE 4070 Ti WINDFORCE (backplate side)
  • GIGABYTE 4080 Gaming OC (backplate side)
  • GIGABYTE 4080 WINDFORCE (backplate side)
  • GIGABYTE 4090 Gaming OC (backplate side)
  • GIGABYTE 4090 WINDFORCE (backplate side)
  • Inno3D 4090 ICHILL X3 (backplate side)
  • MSI Gaming X Trio 4070 Ti (backplate side)
  • MSI Gaming X Trio 4080 (backplate side)
  • MSI Gaming X Trio 4090 (backplate side)
  • MSI Suprim 4070 Ti (backplate side)
  • MSI Suprim 4080 (backplate side)
  • MSI Suprim 4090 (backplate side)
  • MSI Suprim Liquid X 4070 Ti (backplate side)
  • MSI Suprim Liquid X 4080 (backplate side)
  • MSI Suprim Liquid X 4090 (backplate side)
  • MSI Suprim X 4070 Ti (backplate side)
  • MSI Suprim X 4080 (backplate side)
  • MSI Suprim X 4090 (backplate side)
  • NVIDIA 4080 FE (backplate side)
  • NVIDIA 4090 FE (backplate side)
  • PNY 4090 OC XLR8 Gaming Verto EPIC-X RGB TF (backplate side)
  • Watercool HEATKILLER V PRO RTX 4090 FE (backplate side)
Achieve cable management nirvana with the CableMod 12VHPWR 90 Degree Angled Adapter. This low profile adapter plugs into your graphic card’s 16-pin 12VHPWR port, and enables the power cable to be plugged in at a 90 degree angle. Featuring a reinforced PCB design and a sleek profile, this adapter helps increase clearance between the GPU and the side panel – perfect for today’s super wide GPUs. This is the newest v1.1 revision, which includes improved terminals and the new CEM 5.1 female connector.
Discussion (2 replies)
Peter_Brosdahl 👍 1
Here's hoping this fares better than the last one. I quit going to their Reddit page after a while due to all the posts about melted adapters and so on. It just got too depressing and even led to me not ordering anything. I think they are a good company but wow there were a lot of posts.
Zarathustra
Zarathustra
I tried using the old design with my 4090, but sadly it did not work.
The EK waterblock has a recessed slot for plugging in the cable, and the 90 degree adapter simply did not reach all the way down, and was blocked by the plexi surround...
