Cooler Master has announced that it will be releasing a new support bracket for graphics cards called the Atlas ARGB. The bracket, which Cooler Master says was designed for the “most advanced” GPUs, features not only edge-lit ARGB tempered glass, but also an Infinity mirror design for elevating a system’s aesthetics. Other features of the Atlas ARGB include a tool-less design, enabling easy installation, as well as a dual axis support mode that allows for both vertical and horizontal configurations. The stand itself is fully aluminum.
Cooler Master Atlas ARGB GPU Support Bracket Features
- Innovative Infinity Mirror Design: Experience the first-of-its-kind infinity mirror design, housed in a transparent layer, creating a visually striking effect that sets any build apart.
- Edge-Lit ARGB Tempered Glass: Featuring CNC machined ARGB lighting strips complemented by additional ARGB bulbs, this design allows enthusiasts to showcase their GPUs without any obstruction. For a more subtle look, users can simply turn off the lights.
- Sturdy Aluminum Stand: Built with premium materials, the aluminum stand is designed to hold up even the most heavyweight GPUs, ensuring a stable and durable support.
- User-Friendly Installation: Benefit from a 100% tool-free design, ensuring quick and hassle-free installation. Magnets reinforce the base, ensuring robust stability.
- Counteract GPU Sag: With larger GPUs entering the market, the Atlas is purpose-built to support and evenly distribute their weight, ensuring PCIe slots are stress-free.
- Universal Compatibility: The Atlas offers versatility with an adjustable sliding and lock mechanism, compatible across various builds. Furthermore, its dual-axis mode caters to both vertical and horizontal GPU configurations.
Engineered for the most advanced graphics cards, this GPU support accessory melds functionality with cutting-edge design, ensuring GPUs remain stable while providing an additional layer of aesthetics to any PC setup. For enthusiasts who value both performance and design, the Atlas ARGB GPU Support is the perfect addition to elevate the look and longevity of their PC builds.
