be quiet! has announced that its new series of Pure Wings 3 fans will be available for purchase from retailers beginning on Tuesday, November 7, at a starting price of $9.90. The new fans, which come in 120/140 mm sizes and three different versions (3-pin, 4-pin PWM, 4-pin PWM high-speed), feature a new, optimized fan frame that is said to minimize air leakage, with the PWM high-speed options capable of delivering speeds of up to 2,100 RPM with nine airflow-optimized fan blades. These high-speed models also feature a closed loop motor that be quiet! says allows their speeds to always stay on the same level, despite the resistance.
be quiet! Pure Wings 3 Features
- Innovative closed loop motor for high-speed models keeps the rpm no matter the resistance
- Optimized fan frame for outstanding performance on radiators
- Newly designed fan blades and re-arranged angle for extraordinary air pressure
- Pure Wings 3 can be operated with very low minimum rpm for very quiet operation
- Long life rifle bearing gives an operating lifetime of 80,000 hours
- Iconic, unmistakable and streamlined design that avoids anything unnecessary
- Product conception, design and quality control in Germany
Thanks to an optimized fan frame, it delivers outstanding performance on radiators while the newly designed fan blades and re-arranged angle result in extraordinary air pressure.
Optimized for unprecedented air pressure and maximum airflow
The fan frame outlet of Pure Wings 3 is newly designed to minimize air leaks. This benefits especially the radiator performance. To reach even higher performance, the fan blades are optimized as well: their angle is adjusted to achieve even more air pressure, resulting in an unprecedented performance in its class. But Pure Wings 3 doesn’t just perform well on radiators, it’s also the perfect case fan: with optimizations for maximum airflow, Pure Wings 3 is the right choice for any case configuration that demands high cooling performance and a great air circulation. The airflow-optimized fan blades not only reduce noise-generating turbulences but also ensure the performance that is needed, even in demanding configurations. True to the company name, Pure Wings 3 fans are extremely silent thanks to a very low starting rpm and thanks to proven rifle bearing technology, these fans boast a lifespan of 80,000 hours.
High-speed version with closed loop motor for great cooling performance
The Pure Wings 120mm PWM high-speed and Pure Wings 140mm PWM high-speed versions are specifically designed for demanding configurations, increasing the maximum speed to 2100 rpm and 1600 rpm respectively while integrating no less than 9 airflow-optimized fan blades. This results in a remarkably high air pressure of up to 2.41mm/H2O for the 120mm version and 2.44mm/H2O for the 140mm version. And that’s not all: the high-speed models also include a unique closed loop motor, comparable with a cruise control in cars. When working against resistance, fans usually spin slower as a result. The closed loop motor technology constantly monitors the current rpm and increases it to the target, if necessary. As a result, Pure Wings 3 high-speed fans always operate at the desired speed, no matter the resistance.
