Phanteks Expands Glacier One D30 AIO Cooler Lineup with 420mm Model
Image: Phanteks
Phanteks has expanded its Glacier One D30 AIO lineup with the launch of the 420D30 in black or white color options for Intel or AMD processors. Phanteks introduced the Glacier One line with 240mm and 360mm models, featuring its low noise D30 fans with DRGB lighting that can be daisy-chained or connected via a single cable. The AIO copper plate comes pre-coated with thermal paste and Phanteks has also included additional compound. The 420D30 is compatible with most AMD and Intel processors including 14th gen CPUs. Three 140mm D30 PWM fans cool the 420mm aluminum radiator that is 27mm thick.
Image: Phanteks
Description
“The Glacier One D30 AIO cooler is a high-performance cooling solution that offers a smooth D-RGB lighting solution thanks to the D30 fans. The Glacier One D30 AIO cooler equipped with D30 fans, can be daisy-chained and controlled through a single cable. Its large copper base and fin array make it suitable for use with high-end CPUs, while its design allows for maximum clearance with motherboard and RAM components.”
  • High performance water cooling for Sockets Intel LGA 115x, 1200, 1700(Support Intel Core 14th Gen), 2011, 2011-3, 2066 and AMD AM4, AM5
  • Pre-filled for plug-and-play installation reliable operation with reinforced flexible braided tube sleeving, 100% pure copper cold plate and PWM controlled pump and fans.
  • Pre-applied thermal compound and extra Phateks thermal compound included
  • Toolless intuitive mounting system
  • 3x tube clips included to guide the tubing and fan cables
  • Flexible tubing with durable braided sleeving
  • Low profile pump cap designed with rotary fitting staying close to pump to allow for maximum clearance with motherboard and RAM components.
  • Triple 140mm D30 DRGB PWM fans – Smooth D/A-RGB lighting, 30 mm thick and aerodynamic fan blades inspired by the ultimate T30 fan. Easy and clean fan linking system, uses clips to link fans together to reduce cable clutter.
  • D/A-RGB lighting can be controlled and synchronized with Phanteks’ D-RGB lighting products and D/A-RGB equipped cases and motherboards.
Specifications
Image: Phanteks
