Cooler Master Hyper 212 Black CPU Cooler Review
Sound Level Testing
100% Fans
Cooler Master Hyper 212 Black max rpm fan sound testing
At maximum fan levels, the Hyper 212 Black turned in the quietest level of sound at 44.1 dB(A) with the DeepCool AK400 arriving in second place at 46.4 dB(A). Rounding out the rest of the pack was the G6 Stealth at 47.4 dB(A) and the Hyper 212 EVO at 49.4 dB(a).
We noted that the max fan speed on the Cooler Master Hyper 212 Black topped out at 2300 RPM, the Cooler Master Hyper 212 EVO RPM, the DeepCool AK400 topped out at 1850 RPM, and the Iceberg Thermal G6 Stealth has the lowest max fan rpm at 1450 RPM.
1500 RPM Fans
Cooler Master Hyper 212 Black 1500 rpm fan sound testing
Dropping down to 1500 RPM, the Hyper 212 Black continued to lead the pack at 39.9 dB(A) with the AK400 a couple of decibels louder and the Hyper 212 EVO a couple louder than the AK400. The G6 Stealth was the least stealthy at 47.4 dB(A). Keep in mind here that the G6 Stealth is operating at its maximum of 1450 RPM.
1000 RPM Fans
Cooler Master Hyper 212 Black 1000 rpm fan sound testing
When we lowered the fans down to 1000 RPM, the Hyper 212 Black kept the lead with a value of 37.4 dB(A), and the AK400 trailed just behind at 38.7 dB(A). The Hyper 212 EVO and G6 Stealth tied at 40.9 dB(A) to round out the competitors. Subjectively, the coolers were all quiet enough that they all sounded about the same (well, lack of sound is more like it).
600 RPM Fans
While we typically test at 600 RPM for the lowest end of our fans, the Hyper 212 Black’s fan bottomed out at 1100 RPM according to our PWM tuning, so the lowest speed testing can be found in the test above.
With that said, let’s move on and recap all of this for you today!
Cooling Performance
Installation Effort
Sound Level
The Cooler Master Hyper 212 Black is the latest release in a long line of Hyper 212 CPU coolers. It sports solid black trim and a 120mm Sickleflow Edge fan. From a performance perspective, we found it to be the quietest cooler out of the three we compared it to and it had average thermal performance which is perfect for its price point.
