ENERMAX Releases MarbleShell MS31 Mid-Tower and MS21 Mini-Tower Cases with Mesh Front Panel, Better Airflow
Image: ENERMAX
ENERMAX has announced that its MarbleShell MS31 mid-tower and MarbleShell MS21 mini-tower PC cases are available immediately from select retailers and distributors in Europe.
Described as airflow PC cases, these are new cases from the company that are designed to offer better airflow at a lower noise level thanks to a “marble-cutting” mesh front panel, as well as 120 mm ARGB PWM fans.
Users will find four of these pre-installed, but the cases can fit quite a bit more, as ENERMAX explains:
To meet the stronger airflow requirements of modern systems, the MS31 mid-tower case can accommodate up to 11 fans or a 420mm AIO CPU cooler in the front. The MS21 mini-tower case can also install up to 8 fans or a 360mm AIO CPU cooler in the front. The two included magnetic dust filters on the top and front panels can also provide better protection and contribute to extending the lifespan of the sensitive components in the system.
And here’s what ENERMAX has shared regarding the MS31 and MS21’s connectivity and other features, which would include a magnetic side-opening panel:
The MS31 and MS21 boast a modern front panel I/O with 2 x USB 3.0 and 1 x USB 3.2 Type-C ports. The USB 3.2 Type-C port can support data transfer rates of up to 10 Gbps, enabling quicker file transfers and data backups. They also come with an adjustable GPU holder in the package, which will protect your next-gen graphics cards, even the heaviest ones.
Both models feature a magnetic side-opening panel that allows you to have quicker and more convenient access to the interior of the PC during maintenance. The reusable PCIe expansion slots will also provide more flexibility when upgrading or replacing components.
A full listing of cases that ENERMAX currently has on offer can be found here.
ENERMAX MS31 and MS21 Specifications
Key SpecificationMS31MS21
ColorBlack/WhiteBlack/White
Dimensions415mm (D) x 210mm (W) x 470mm (H)370mm (D) x 210mm (W) x 435mm (H)
Motherboard SupportE-ATX, ATX, Micro-ATX, Mini-ITXMicro-ATX, Mini-ITX
Radiator Compatibility120mm, 240mm, 280mm, 360mm, 420mm120mm, 240mm, 280mm, 360mm
Max GPU Length410mm365mm
Max CPU Cooler Height162mm162mm
PCIe Expansion Slots75
Warranty2 Years2 Years
Image: ENERMAX
