TEAMGROUP Announces T-FORCE SIREN GD120S M.2 2280 SSD AIO Liquid Cooler
Image: TEAMGROUP
TEAMGROUP has announced the T-FORCE SIREN GD120S SSD 120mm AIO cooler designed for M.2 2280 drives and featuring an ARGB PWM fan that can operate from 600-2200 RPM. The water block is made from aluminum alloy with a copper plate. A three-phase 4000 RPM water pump is located in the 120mm radiator and utilizes a porcelin axis which TEAMGROUP says enables efficient low-noise operation. TEAMGROUP’s testing has shown PCIe GEN5 SSD temperature improvements by up to 35% when using the T-FORCE SIREN GD120S. Temperatures for the PCIe GEN5 SSD were reported to be under 54°C during heavy load testing. TEAMGROUP has announced that the T-FORCE SIREN GD120S SSD comes with a 3-year warranty and will become available towards the end of December but has not revealed its price.
Image: TEAMGROUP
Press Release (via news page):
The SSD water block fits perfectly with M.2 2280 SSDs and provides superb cooling performance, enabling SSDs to maintain optimal low-temperatures and stable operation. Based on tests, the SIREN GD120 allows PCIe 5.0 SSDs to stay under 54°C even during heavy load【1】, providing global players with more diverse cooling solutions for M.2 SSD high temperatures.
The T-FORCE SIREN GD120S AIO SSD Cooler boasts excellent cooling performance by equipping the precision aluminum alloy dual-tube water blocks with double-layered thermal pads, which allow the SSD controller chip and IC to be tightly affixed to the copper base of the cooler. The pump utilizes a ceramic shaft design and three silent motors to achieve silent, highly efficient, and stable liquid cooling. Furthermore, the T-FORCE SIREN GD120S AIO SSD Cooler uses a 120mm radiator with 13 high-density aluminum fins to increase the cooling area, effectively removing the high temperatures generated by M.2 PCIe 5.0 SSDs. Its 12 cm ARGB PWM fan can also accurately adjust speeds based on system temperature to achieve optimal heat dissipation while saving energy and providing a customized lighting effect.
The T-FORCE SIREN GD120S AIO SSD Cooler demonstrates its powerful cooling function while caring for the earth and environmental sustainability. It is manufactured using environmentally friendly processes, RoHS compliant, and packaged with recyclable materials. The T-FORCE SIREN GD120S AIO SSD Cooler will first be available on Amazon in North America at the end of December. Please stay tuned to the latest news on TEAMGROUP’s official website and social media channels.
Specifications (via product page):
  • SSD Socket: NVMe M.2 2280
  • Water Block Dimension: 70 x 23.8 x 28.7 mm
  • Block Plate Material: Copper
  • Block Material: Aluminum
  • Radiator Dimension: 120 x 120 x 27 mm
  • Radiator Material: Aluminum
  • Pump Speed: 4000±10% RPM
  • Pump Rated Current and Power Consumption: 0.34 A (0.45 A MAX), 4.08 W (5.4 W MAX)
  • Pump Noise and Flow: 22 dBA, 850 ml/min
  • Pump Operating and Storage Temperature: -20℃~+60℃, -20℃~+70℃
  • Fan Number of Fans 1
  • Fan Dimension 120 x 120 x 25 mm
  • Fan Rated Voltage and Power Consumption: Voltage 12 V, 1.68-3.84 W (LED 3.12 W)
  • Control Method 4-pin PWM
  • Fan Speed and Noise: 600-2200 RPM, 14.3-35.6 dBA
  • Air Flow and Pressure: 25.62-93.97 CFM, 0.26-3.53 mm-H2O
  • Tube Length: 400 mm
  • Accessories: ARGB Splitter Cable x1
  • Warranty: 3-year warranty
