GAMDIAS Debuts Its New CHIONE M4 Series Liquid Coolers with Patented Inline PWM Pump and LCD Display
Image: GAMDIAS
PC owners looking for an efficient CPU cooler have new options as GAMDIAS debuts its new CHIONE M4 line of CPU AIO coolers featuring an inline pump and a rotatable 2.1″ LCD cooler display. Available in 240mm, 360mm, and 420mm cooling capacities the CHIONE M4 series is compatible with Intel LGA 1700 and AMD AM5 processors and comes with universal installation kits. The inline pump is rated for up to 5400 RPM and the cooling tubes are made from 450mm Teflon and insulated inside nylon braided sleeves. GAMDIAS has increased radiator fin thickness by 25%-40% for improved heat dissipation which is then paired with hydraulic bearing PWM fans featuring ARGB lighting.
The LCD cooler display shows the fan and pump speeds, and CPU temperature with further customization options via its very clean-looking included software that also provides complete control over the AIO. The 120mm cooling PWM fans for the CHIONE M4 240mm and 360mm can operate at up to 2000 RPM for a maximum of 69.01 CFM while the 140mm PWM fans for the 420mm operate at 1600 RPM but with an increase of 90 CFM. All three coolers have a beefy 32mm thick radiator and their fans operate at a relatively quiet 11-29 dBA for near-silent operation.
Per GAMDIAS:
“GAMDIAS DEBUTS CHIONE M4 LCD DISPLAY LIQUID COOLER”
“The CHIONE M4 delivers powerful cooling for your CPU through its patented in-line PWM pump, a 32mm thick radiator, and hydraulic ARGB fans to reach an advanced level of coolness. It also features a 2.1” LCD screen on the water block that displays CPU temperature, fan speed, and pump speed stats in real-time.”
CHIONE M4 Series Key Features (via official page):
  • Rotatable 2.1” LCD, Displays Real-time System Information
  • New Cooling Route System for Better Performance
  • Patented in-line PWM Pump up to 5400 RPM
  • 25%-40% Increase in Radiator Fin Thickness
  • Optimized Copper Base for Better CPU Contact
  • Rotatable CPU Water Block
  • CHIONE CAST LITE Software
  • ARGB Motherboard sync
  • 450mm Durable Teflon Tube With Aesthetic Nylon-braided Tube Sleeve
  • Hydraulic Bearing PWM Fans
  • Support LGA 1700 / AM5
