MaxSun Launches Mega Gamer GeForce RTX 4070 MGG with Five Fans, 215-Watt TDP
Image: MaxSun
MaxSun has released the GeForce RTX 4070 MGG OC12G S0, a custom version of NVIDIA’s mid-range Ada GPU for gamers that, despite having a relatively modest 215-watt TDP, apparently requires five fans to cool itself properly.
Here’s the specifications for the graphics card, which is now available in China and features the usual triple-fan setup, but complemented with two additional, smaller fans on the facing side:
MaxSun GeForce RTX 4070 MGG OC12G S0 Specifications
  • display core: NVIDIA GeForce RTX 4070
  • Architecture model: Ada Lovelace
  • Core code name: AD104
  • Core craftsmanship: 5nm
  • stream processor: 5888
  • core frequency: 1920MHz
  • Core dynamic acceleration frequency: 2580MHz
  • Memory frequency: 21000MHz
  • Memory capacity: 12GB
  • Video memory type: GDDR6X
  • Video memory bit width: 192bit
  • Bus interface type: PCI Express X16 4.0
  • display interface: DP3/HDMI
  • maximum resolution: 7680×4320 Pixel DisplayPort resolution
  • External power supply: 12+4Pin power supply
  • TDP: 215W
  • Recommended power supply: 650W or more
  • 3D API: DirectX 12, Shader Model 5.0, OpenGL 4.5
  • System Requirements: Windows 10
  • Size: 337137*66(mm)
And here are some of the product shots and marketing graphics for the card, which costs ¥5,299 (~$741 USD), according to JD.com’s listing:
MaxSun GeForce RTX 4070 MGG OC12G S0 Gallery
MaxSun GeForce RTX 4070 MGG OC12G S0 Features
