Xbox Stealth Ultra Wireless Controller with Built-In Dashboard Screen and Anti-Drift Sticks Releases for $199.99
Image: Turtle Beach
Turtle Beach has announced that the Stealth Ultra Wireless Controller is now available to purchase for $199.99 on www.turtlebeach.com and at participating retailers worldwide.
Here’s a breakdown of the key features that users will find with the Stealth Ultra Wireless, including thumb sticks that are seemingly immune to stick drift, as well as a 1.5-inch full-color “Connected Command Display” for adjusting button mapping and more:
  • High-Performance, Lag-Free Wireless Technology
  • 30-Hour Battery Life with Adjustable Power Modes
  • Connected Command Display for Extensive Settings Adjustments
  • AntiDrift Thumbsticks for Long-Lasting, Smooth Control
  • Tactile Microswitch Buttons for Faster, More Reliable Response
  • Durable, Hard-Shell Case with Charge-Through Capability
  • Four Mappable Quick-Action Buttons
And here’s what Turtle Beach had to say about the controller, a Designed for Xbox peripheral:
The Stealth Ultra uses Turtle Beach’s proprietary low-latency wireless technology for connecting with Xbox consoles and Windows PCs, and Bluetooth for gaming on compatible Smart TVs and Android mobile devices. An abundance of class-leading features begins with magnetic AntiDrift Hall Effect thumbsticks, precise and tactile microswitch buttons, and the innovative Connected Command Display dashboard that provides deep customization options. Adjustable short and long-pull triggers, four mappable buttons on the back, RGB lighting, plus the option to receive social notifications on the controller create the ultimate package for gamers who demand the absolute best.
An immediately noticeable key feature that sets Turtle Beach’s Stealth Ultra controller apart from the competition is a first-of-its-kind, integrated 1.5” full-color Connected Command Display. Through the Connected Command Display dashboard gamers can customize the Stealth Ultra’s performance aspects like button mapping, thumbstick response, dead zones, vibration intensity, game and chat audio, and power settings, as well as adjust its 16.8 million RGB colors for aesthetics, notifications, and low battery warnings. The Connected Command Display also gives players on-the-fly access to adjustments for 10 onboard profiles that can be created for different games, genres, or character loadouts. Plus, patented Turtle Beach technology, exclusive to the Stealth Ultra, allows gamers to send social notifications from their phone to the Connected Command Display on the controller.
Beyond customization and appearance, the Stealth Ultra is designed for reliable performance and longevity. The Stealth Ultra’s AntiDrift thumbsticks use magnetic, contactless Hall Effect sensors to enhance accuracy and improve durability, and two extra sets of domed thumbstick caps are included for added customization. It features premium materials throughout, including soft-touch finishes and a comfortable ergonomic shape with micro-cooling channels. Precise and tactile microswitches rated at five million clicks are used throughout the Stealth Ultra in the D-Pad, ABXY cluster, mappable buttons, and bumpers for fast, reliable responses with every press.
The Stealth Ultra’s short and long-pull triggers are adjustable so gamers can customize the feeling for short hair triggers in action and FPS games, to full travel distance for fine adjustment of throttle and braking in racing games. Plus, the Stealth Ultra features four mappable quick-action buttons on the underside so gamers can configure their exact control preferences to the game being played. Turtle Beach’s Pro-Aim Focus Mode also returns in the Stealth Ultra, which allows gamers to tune thumbstick sensitivity for enhanced long-range accuracy and is selectable as a preset for any of the four mappable buttons on the back of the controller. Dual-rumble motors in the Stealth Ultra’s handles and triggers provide immersive vibration feedback and are also adjustable through the Connected Command Display dashboard.
The included low-profile, high-speed charge dock provides Stealth Ultra a convenient place to rest and charge when not in use. There are also a variety of adjustable power modes, including Eco Mode that turns off RGB lighting, allowing gamers to extend the Stealth Ultra’s battery life up to 30-hours on a single charge. High-speed USB 3.0 charging gets the controller back to 100% charge in under two hours. The charge dock also has a built-in USB port for connecting the controller’s wireless transmitter, and only takes up one USB port on Xbox or PC. The Stealth Ultra also comes with a 10ft / 3m USB cable, providing the ability to play and charge when needed.
The Stealth Ultra wouldn’t be a true Turtle Beach game controller without also providing the brand’s suite of gaming audio features. As with Turtle Beach’s award-winning Recon and REACT-R controllers, the Stealth Ultra also enhances any wired gaming headset connected via the 3.5mm jack with exclusive Turtle Beach-only audio features, including Superhuman Hearing for a competitive advantage, EQ audio presets, game and chat volume mix, mic monitoring, and more.
In addition to using the Stealth Ultra’s integrated Connected Command Display, gamers can also adjust their settings through the Control Center 2 companion app available on Xbox and Windows PCs, and on Android and iOS mobile devices. When not in use, the Stealth Ultra controller, charge dock, cables, and additional thumbcaps can be stored in the included hardshell travel case, which has a built-in slot to charge the Stealth Ultra while in its case.
