ENERMAX Releases StarryKnight SK30 V2 Airflow Mid-Tower PC Case with USB 3.2 Gen 2 Type-C and Powerful ARGB Fans
ENERMAX, an industry-leading force dedicated to designing high-performance computer hardware and cooling solutions, today announced the new StarryKnight SK30 (SK30 V2) mid-tower PC case, a follow-up and upgrade of its last-generation SK30 PC case.
The SK30 V2 comes with three pre-installed 140mm and one 120mm ENERMAX SquA RGB ADV fans with PWM function. The SquA RGB ADV fan, as one of ENERMAX’s most powerful ARGB fans, delivers 40% stronger airflow than other regular-case fans with an enlarged blade surface. The combination of air-inlet and vortex-frame design will not only bring in more air but also direct and concentrate airflow across the system’s components.
Image: ENERMAX
In addition to two USB 3.2 ports, the SK30 V2 now comes with a USB 3.2 Gen 2 Type C port, which allows higher data transfer speeds and makes it easier for users to connect and charge devices without needing multiple types of cables and adapters.
Image: ENERMAX
The SK30 V2 also comes with a 6-port control hub that supports ARGB lighting effects synchronization as well as a PWM fan hub. The I/O reset button allows users to switch between 13 pre-set lighting effects without any additional software installation.
Image: ENERMAX
The SK30 V2 is ideal for high-performance PC builds, thanks to the mesh front panel and wider interior space, supporting graphic cards up to 405mm in length allowing users to have excellent expandability.
ENERMAX StarryKnight SK30 V2 Specifications
The SK30 V2 is available immediately on Newegg and ENERMAX webstore in the United States. For up-to-date availability information, please refer to the ENERMAX website or contact your local ENERMAX sales representative.
Image: ENERMAX
